nitishn5
Full Member level 6
- Joined
- Mar 27, 2011
- Messages
- 386
- Helped
- 92
- Reputation
- 186
- Reaction score
- 104
- Trophy points
- 1,323
- Location
- Bangalore, India, India
- Activity points
- 4,366
I have a three stage LDO with an external capacitor and PMOS pass device.
During Power up, the external capacitor has to be charged up and hence the Pass device is fully ON, i.e., the LDO is slewing.
My problem is that in some cases/corners, the Output voltage overshoots the reference and goes till the supply voltage.
Since the pull down current is very small, the LDO takes a long time to settle back to the final voltage.
My understanding of Slewing is as follows
1. The Output will slew till it is within the input range of the Error Amplifier. During this time the gate of the Pass Transistor is low.
2. Once it is in the range, the gate of the pass device has to be pulled up as fast as possible.
3. If it is not fast enough, the output voltage will overshoot since the current coming in is much more than the current going out.
4. Once it has overshot, the settling will be determined by the pull-down current discharging the capacitor.
My questions are :
Is my understanding correct?
Can I prevent the overshoot by increasing the speed(bandwidth) of the LDO?
My questions are :
