Junus2012
Advanced Member level 5
Hi
I have to drive a resistive load from the operation amplifier. I am using single ended op-amp so the common mode voltage (VCM ) is VDD/2. I am inquiring where I should connect the resistor , from output to ground or from output to VCM .???
with the discreet amplifier we usually work with single supply voltage but the load is referenced to ground but I am not sure with Op-Amp,
Thank you
Thank you
