[SOLVED] Single Phase Converters (Power Electronics , Rectifiers Using Thyristors)
wfg42438
Member level 3
California
Hello,
Below are plots for two idealized single phase converters where the source inductance is 0
Case 1 the converter has a sinusoidal input applied to 4 thyristors and with a DC current source as a load
Case 2 the converter has a sinusoidal input applied to 2 thyristors, 2 diodes and with a DC current source as a load
Now based on the text i know thyristors require a pulse applied to its gate terminal in order to begin conduction
The time at which this current is applied is what we call "alpha"
For Case 1 before wt=alpha we have a negative voltage building up, can someone please explain what is happening for this to occur??
When looking at Case 2 the negative voltage we observed earlier prior to wt=alpha is no longer the case. We simply have a positive voltage produced after alpha, why has this changed in case 2?
Any insight and help would be greatly appreciated!!!
Please disregard this question i have already figured it out!
