I am designing a single rectangular patch antenna for 2.4Ghz. i am using inset feed. I used the std formulas available in Balanis to cal the length and width of rectangular patch.
The length = 30mm, width=38mm, Er=4.4,height of substrate(fr4)=1.6mm. The feed width was 0.5mm.
I am using ADS software for stimulation. The results were
@2.322GHz |S11|=-11db. which means the return loss is 11db. This was my max return loss. @2.4Ghz the return loss was around 5db.
I would like to improve my results....
I want a return loss greater than 17db at least.And the frequency should be very closer to 2.4Ghz.I have planned for fabrication .so i cant change the Er.
so pls tell me a way to improve my result.
Thanks
shobi
