I wonder if any body has worked with a load cell that can measure weights from as small as 200 grams to as large as 50 ton. And I mean a single load cell for the entire range with good accuracy.
That's what I thought I should do.
But if, for example, I use two cells, would the small-range one be able to mechanically withstand the heavy load that the other one is to measure? Have you seen any similar implementations?
Thank you.
This is impossible.
You have to use load cells in class C6 (6000div). Indicator must be guaranteed 100000div and then emin=~300g-500g with one load cells.
I built weight scales Max=40000kg and e=400g and I have more problems with stability measurement.
