prasimix
Newbie level 2
I'm searching for a buck regulator (could be controller too) that has programmable voltage and current. The first one shouldn't be a problem but for current it should have something like Imon and Iset/Ictrl pins. In that way I can use MCU's DAC/PWM output to set both voltage and current, and also ADC inputs to monitor them.
Input voltage is 12 VDC, and output should be variable e.g. 1-5 V and up to 4-5 A (max. power 25-30 W). So far I found only one candidate LT8613. It looks fine but its tiny QFN package is not so DIY-friendly or it is? Another possibility is regulator/controller with I2C or SPI bus that can be used for programming and monitoring output voltage and current in above mentioned range.
Thanks in advance!
Thanks in advance!
