Simulated DAQ in LAbview 6
nitr8
Member level 3
Member level 3
Look behind
HI,
Does any one know where is the simulated daq in labview 6 . I think it has been excluded from it.
Is there a way to add it.
Trishool
Full Member level 1
Full Member level 1
Himalayas.(mount K2)
nitr8 when you order the CD from ni.com you get two CD's one contains
6i the other which is named instrupedia contains demo simulated software
for labview 6.0.1 in that you can find DAQ .
Goodluck
Ts
nitr8
Member level 3
Member level 3
Look behind
cool thanks pal
i've ordered the instrupedia.
Thanks
nitr8
Member level 3
Member level 3
Look behind
In the insrupedia cd the simulated daq is included as a seperate installation or do i have to install labview in the cd to get simulated daq.
yhk
Junior Member level 1
No you don't have to. However if it asks for you to do so, then i think you should. Since Labview is a general programing language, and if you know signal process, you can write you own simulations quite easy.
nitr8
Member level 3
Member level 3
Look behind
I don't want to install the trial version of labview to get simulated DAQ. i already have Labview 6 installed.
There should be some other way to add it. I'm not an expert and i can't write my own simulations. I can't seem to find it in the instrupedia cd.
Simulated Daq is installed by default in labview student version since students can't afford to buy the daq board so they can use the simulated daq instead.
nitr8
Member level 3
Member level 3
Look behind
come on guys someone might know the answer. Labview is usless to me with out the simulated daq.
frankfan
Member level 1
Member level 1
hi guys,
there are a lot of stuff about NI products like Labview6i, HIQ, IMAQ, DAQ, Measurement Studio and ActiveX on Frontier server in hotline.
24.1.213.10
thanks Frontier and uploader for sharing.
Best Regards
nukhung
Member level 2
Member level 2
How to connect to Frontier server in hotline. Please advice me. Thanks
