pankaj1984
sim900 is set to auto baud by factory default,
what i did was to send at+ipr=xxxx baudrate i am using continously until i got the response ok,
hi sir,
i am having same problem. Initially the modem was giving me the delta values and garbage values at 9600 baud, later on at lower baud rate 4800 baud i was able to type 'at' but when i pressed enter the modem is not responding 'ok', i have other sim900 module it is also giving the same output, as per the sim900 serial communication appnote it is mentioned. The delta values that we see are the sync characters that sim900a send to the hyper terminal.
1.> after power on 2-3 sec wait, type 'a' for baud rate sync.
2.> then type 'at' until you get reply 'ok'.(which i am not getting)
i tried to type 'at' almost 50 time but the modem is not responding,
3.> i also tried at+ipr=4800 but its not responding.
The only improvement i have seen is that at lower baud, i am able too type "at" commands in the hyper terminal window.i am using cross cable. And i think its working fine.
Please let me know if anybosy has solution to this problem
