there will be ignition switch other than power ON switch... check if it is ON...
check if the cable is working properly....
modem may be receiving commands from terminal but not replying means modem in unable to transmit, but coould receive, so change max 232 in modem and check with both configuration of tx and rx in cable....
dont use sms or short hand typing skills in this forum... type the complete words by spending few more seconds. this is the last warning and further posts and thread of yours will be deleted without informing you if continued
hi muwasifProblem solved
I am still finding the key problem but what I doubt it was <\r> I used every time when sending 'A' for baud rate sync. I'll update if I got any other reason
Thank you for your timely response.
It indicates that your module is restarting continuously. Make sure that there is no repeating pulse at pin 5 of conn1.i get repeated default (RDY) response from the module on powering up, even if i don't send anything, 50-60 times a second.
i am using lm317 for power supply...
