SIM300CZ GPRS IP Status errors when sending AT+CIPSTART command
micropinger
Newbie level 1
iran
sim300cz
Hi
When i send AT+CIPSTART="TCP","www.takline-co.com","80" i got it :
OK
and after 5 second :
ERROR: 6
STATE: IP STATUS
please help me.
my settings are :
AT+CGATT=1
OK
AT+CGDCONT=1,"IP","mtnirancell"
OK
AT+CSTT="mtnirancell","",""
OK
AT+CIICR
OK
AT+CIFSR
10.13.49.134
AT+CIPSTATUS
OK
STATE: IP STATUS
AT=CIPHEAD=1
OK
AT+CDNSORIP=0
OK
OK
ERROR: 6
STATE: IP STATUS
AT+CIPSEND
ERROR
My operstor GPRS settings are:
APN : mtnirancell
WAP Proxy : 10.131.26.138
Port : 9201
Service : CO-WSP
HTTP Proxy : 10.131.26.138
Port : 8080
i also set AT+CDNSCFG="10.131.26.138" and AT+CDNSORIP=1 and i sent AT+CIPSTART="TCP","www.takline-co.com","80"
OK
after 30 second
ERROR: 5
STATE: IP STATUS
please help me.
thanks
movie_freak
Member level 5
sim300cz + gprs
AT+CIFSR
10.13.49.134
It shows a local IP. It cannot connect to the internet. You need to get a 3 digit IP to connect to the internet from the SIM card.
Note: This is only my observance.
I used to get the two digit IP either when i had a sim like airtel or vodafone with only gprs activated (internet not activated). This facility is charged seperately whereas free airtellive gprs is free which cannot be used for this purpose. So you may check with your simcard and operator
Also when using APN u need to check:
e.g.
if you use protalnmms for vodafone u'll never be able to get connected to any IP regardless of the SIM having the capability to connect to the internet.
whereas
if you use www instead of portalnmms for vodafone with the same sim card u will be able to connect to the required server.
Surya
GSM Man
Banned
New Jersey, USA
sim300cz gprs
movie_freak said:
AT+CIFSR
10.13.49.134
You'll always get a local IP unless you have a service plan that allows you to accept incoming requests - only then will you be granted a public IP address. You can connect to the Intenet with a local IP - just as your PC can connect to the Internet when connected to a LAN (it also has only a local IP).
For the 'AT+CDNSCFG' command you supplied a local IP address. Usually the DNS servers are at a public address. Did you get this address from your service provider as the address of their DNS server?
Are you sure the APN, user name and password are correct for your service provider?
mpch_elec
Member level 1
Tehran,Iran
proxy-connection: close, at+cipsend, error
hi friends,
i need simm300 v3.04 pin descrption.
i want to design a circuit.
thanks.
varunprakash
Newbie level 2
Theni
sim300cz at command in english
mpch_elec said:
hi friends,
thanks.
Kandeepan
Junior Member level 1
Hi Friends, Could you please let me know to establish a connection to FTP server via GPRS. I'm using SIM300cz, Orange- UK SIM. An early reply is very much appriciated.
Kind regards
Kande
