sun_ray
Advanced Member level 3
In a mixed signal design, signals will pass from analog to digital domain and vice-versa. What are the typical guidelines for signals passing from analog to digital?
Regards
Regards
Why is it necessary?In scan mode, signals from analog to digital should be not toggling and signals from digital to analog should be some safe value.
So your analog logic doesn't start doing some random function, and in the reverse direction, so help improve test coverage.Why is it necessary?
Can you break up your sentences so that the meaning out of your sentences are clear? Random function in which sense? Random function in forward or backward direction?So your analog logic doesn't start doing some random function, and in the reverse direction, so help improve test coverage.
