thetrice
Junior Member level 1
- Joined
- Mar 26, 2013
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,406
Error appears in translate phase that signal clkin2 has multiple drivers although it doesnt , main clock signal enters a DCM which generates 2 clock singles 1 acts as a clock for my vhdl module and other act as a clock for microblaze , the clkin2 is the clock of microblaze and its telling me it has multiple drivers .. here is the code for my top vhdl :
and here is the code of DCM component :
-- micro_top.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
entity micro_top is
port (
-- clkin: in std_logic;
fpga_0_RS232_Uart_1_RX_pin : in std_logic;
fpga_0_RS232_Uart_1_TX_pin : out std_logic;
fpga_0_DIP_Switches_4Bit_GPIO_IO_pin : inout std_logic_vector(0 to 3);
fpga_0_Ethernet_MAC_PHY_tx_clk_pin : in std_logic;
fpga_0_Ethernet_MAC_PHY_rx_clk_pin : in std_logic;
fpga_0_Ethernet_MAC_PHY_crs_pin : in std_logic;
fpga_0_Ethernet_MAC_PHY_dv_pin : in std_logic;
fpga_0_Ethernet_MAC_PHY_rx_data_pin : in std_logic_vector(3 downto 0);
fpga_0_Ethernet_MAC_PHY_col_pin : in std_logic;
fpga_0_Ethernet_MAC_PHY_rx_er_pin : in std_logic;
fpga_0_Ethernet_MAC_PHY_rst_n_pin : out std_logic;
fpga_0_Ethernet_MAC_PHY_tx_en_pin : out std_logic;
fpga_0_Ethernet_MAC_PHY_tx_data_pin : out std_logic_vector(3 downto 0);
fpga_0_Ethernet_MAC_PHY_MDC_pin : out std_logic;
fpga_0_Ethernet_MAC_PHY_MDIO_pin : inout std_logic;
fpga_0_Ethernet_MAC_MDINT_pin : in std_logic;
LED: out std_logic_vector(3 downto 0);
fpga_0_MCB_DDR3_mcbx_dram_addr_pin : out std_logic_vector(12 downto 0);
fpga_0_MCB_DDR3_mcbx_dram_ba_pin : out std_logic_vector(2 downto 0);
fpga_0_MCB_DDR3_mcbx_dram_ras_n_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_cas_n_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_we_n_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_cke_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_clk_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_clk_n_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_dq_pin : inout std_logic_vector(15 downto 0);
fpga_0_MCB_DDR3_mcbx_dram_dqs_pin : inout std_logic;
fpga_0_MCB_DDR3_mcbx_dram_dqs_n_pin : inout std_logic;
fpga_0_MCB_DDR3_mcbx_dram_udqs_pin : inout std_logic;
fpga_0_MCB_DDR3_mcbx_dram_udqs_n_pin : inout std_logic;
fpga_0_MCB_DDR3_mcbx_dram_udm_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_ldm_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_odt_pin : out std_logic;
fpga_0_MCB_DDR3_mcbx_dram_ddr3_rst_pin : out std_logic;
fpga_0_MCB_DDR3_rzq_pin : inout std_logic;
fpga_0_MCB_DDR3_zio_pin : inout std_logic;
fpga_0_clk_1_sys_clk_p_pin : in std_logic;
fpga_0_clk_1_sys_clk_n_pin : in std_logic;
fpga_0_rst_1_sys_rst_pin : in std_logic
-- xps_gpio_0_GPIO_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_0_GPIO2_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_1_GPIO_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_1_GPIO2_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_2_GPIO_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_2_GPIO2_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_3_GPIO_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_3_GPIO2_IO_I_pin : in std_logic_vector(0 to 31);
-- xps_gpio_4_GPIO_IO_O_pin : out std_logic_vector(0 to 3);
-- xps_gpio_5_GPIO_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_5_GPIO2_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_6_GPIO_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_6_GPIO2_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_7_GPIO_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_7_GPIO2_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_8_GPIO_IO_O_pin : out std_logic_vector(0 to 31);
-- xps_gpio_8_GPIO2_IO_O_pin : out std_logic_vector(0 to 31);
-- clock_generator_0_CLKOUT3_pin : out std_logic
end micro_top;
architecture STRUCTURE of micro_top is
component mycode is
port(
clk:in std_logic;
Input_1:in std_logic_vector((32)-1 downto 0);
Input_2:in std_logic_vector((32)-1 downto 0);
Input_3:in std_logic_vector((32)-1 downto 0);
Input_4:in std_logic_vector((32)-1 downto 0);
Input_5:in std_logic_vector((32)-1 downto 0);
Input_6:in std_logic_vector((32)-1 downto 0);
Input_7:in std_logic_vector((32)-1 downto 0);
Input_8:in std_logic_vector((32)-1 downto 0);
ready:in std_logic_vector(3 downto 0);
state:out std_logic_vector(3 downto 0);
Output_1:out std_logic_vector((32)-1 downto 0);
Output_2:out std_logic_vector((32)-1 downto 0);
Output_3:out std_logic_vector((32)-1 downto 0);
Output_4:out std_logic_vector((32)-1 downto 0);
Output_5:out std_logic_vector((32)-1 downto 0);
Output_6:out std_logic_vector((32)-1 downto 0);
Output_7:out std_logic_vector((32)-1 downto 0);
Output_8:out std_logic_vector((32)-1 downto 0)
end component;
component clk_wiz_v3_6 is
port (-- Clock in ports
CLK_IN1 : in std_logic;
-- Clock out ports
CLK_OUT1 : out std_logic;
CLK_OUT2 : out std_logic
end component;
component micro is
port (
fpga_0_rst_1_sys_rst_pin : in std_logic;
end component;
signal clkin :std_logic;
-- signal feedback :std_logic;
signal clkin2:std_logic;
signal xps_gpio_0_GPIO_IO_I_pin :std_logic_vector(0 to 31);
signal xps_gpio_0_GPIO2_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_1_GPIO_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_1_GPIO2_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_2_GPIO_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_2_GPIO2_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_3_GPIO_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_3_GPIO2_IO_I_pin : std_logic_vector(0 to 31);
signal xps_gpio_4_GPIO_IO_O_pin : std_logic_vector(0 to 3);
signal xps_gpio_5_GPIO_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_5_GPIO2_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_6_GPIO_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_6_GPIO2_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_7_GPIO_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_7_GPIO2_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_8_GPIO_IO_O_pin : std_logic_vector(0 to 31);
signal xps_gpio_8_GPIO2_IO_O_pin : std_logic_vector(0 to 31);
signal clock_generator_0_CLKOUT3_pin : std_logic;
attribute BUFFER_TYPE : STRING;
attribute BOX_TYPE : STRING;
attribute BUFFER_TYPE of fpga_0_Ethernet_MAC_PHY_tx_clk_pin : signal is "IBUF";
attribute BUFFER_TYPE of fpga_0_Ethernet_MAC_PHY_rx_clk_pin : signal is "IBUF";
attribute BOX_TYPE of micro : component is "user_black_box";
begin
dcmer:clk_wiz_v3_6
port map (
CLK_IN1 =>fpga_0_clk_1_sys_clk_p_pin,
-- CLKFB_IN => open,
-- Clock out ports
CLK_OUT1=>clkin,
CLK_OUT2 =>clkin2
-- CLKFB_OUT => open
unit1 : mycode port map (
clk=>clkin,
Output_1=> xps_gpio_0_GPIO_IO_I_pin,
Output_2=> xps_gpio_0_GPIO2_IO_I_pin,
Output_3=> xps_gpio_1_GPIO_IO_I_pin,
Output_4=> xps_gpio_1_GPIO2_IO_I_pin,
Output_5=> xps_gpio_2_GPIO_IO_I_pin,
Output_6=> xps_gpio_2_GPIO2_IO_I_pin,
Output_7=> xps_gpio_3_GPIO_IO_I_pin,
Output_8=> xps_gpio_3_GPIO2_IO_I_pin,
ready=> xps_gpio_4_GPIO_IO_O_pin,
state=>LED,
Input_1=> xps_gpio_5_GPIO_IO_O_pin,
Input_2=> xps_gpio_5_GPIO2_IO_O_pin,
Input_3=> xps_gpio_6_GPIO_IO_O_pin,
Input_4=> xps_gpio_6_GPIO2_IO_O_pin,
Input_5=> xps_gpio_7_GPIO_IO_O_pin,
Input_6=> xps_gpio_7_GPIO2_IO_O_pin,
Input_7=> xps_gpio_8_GPIO_IO_O_pin,
Input_8=> xps_gpio_8_GPIO2_IO_O_pin
--LED<=xps_gpio_4_GPIO_IO_O_pin;
micro_i : micro
port map (
fpga_0_RS232_Uart_1_RX_pin => fpga_0_RS232_Uart_1_RX_pin,
fpga_0_RS232_Uart_1_TX_pin => fpga_0_RS232_Uart_1_TX_pin,
fpga_0_DIP_Switches_4Bit_GPIO_IO_pin => fpga_0_DIP_Switches_4Bit_GPIO_IO_pin,
fpga_0_Ethernet_MAC_PHY_tx_clk_pin => fpga_0_Ethernet_MAC_PHY_tx_clk_pin,
fpga_0_Ethernet_MAC_PHY_rx_clk_pin => fpga_0_Ethernet_MAC_PHY_rx_clk_pin,
fpga_0_Ethernet_MAC_PHY_crs_pin => fpga_0_Ethernet_MAC_PHY_crs_pin,
fpga_0_Ethernet_MAC_PHY_dv_pin => fpga_0_Ethernet_MAC_PHY_dv_pin,
fpga_0_Ethernet_MAC_PHY_rx_data_pin => fpga_0_Ethernet_MAC_PHY_rx_data_pin,
fpga_0_Ethernet_MAC_PHY_col_pin => fpga_0_Ethernet_MAC_PHY_col_pin,
fpga_0_Ethernet_MAC_PHY_rx_er_pin => fpga_0_Ethernet_MAC_PHY_rx_er_pin,
fpga_0_Ethernet_MAC_PHY_rst_n_pin => fpga_0_Ethernet_MAC_PHY_rst_n_pin,
fpga_0_Ethernet_MAC_PHY_tx_en_pin => fpga_0_Ethernet_MAC_PHY_tx_en_pin,
fpga_0_Ethernet_MAC_PHY_tx_data_pin => fpga_0_Ethernet_MAC_PHY_tx_data_pin,
fpga_0_Ethernet_MAC_PHY_MDC_pin => fpga_0_Ethernet_MAC_PHY_MDC_pin,
fpga_0_Ethernet_MAC_PHY_MDIO_pin => fpga_0_Ethernet_MAC_PHY_MDIO_pin,
fpga_0_Ethernet_MAC_MDINT_pin => fpga_0_Ethernet_MAC_MDINT_pin,
fpga_0_MCB_DDR3_mcbx_dram_addr_pin => fpga_0_MCB_DDR3_mcbx_dram_addr_pin,
fpga_0_MCB_DDR3_mcbx_dram_ba_pin => fpga_0_MCB_DDR3_mcbx_dram_ba_pin,
fpga_0_MCB_DDR3_mcbx_dram_ras_n_pin => fpga_0_MCB_DDR3_mcbx_dram_ras_n_pin,
fpga_0_MCB_DDR3_mcbx_dram_cas_n_pin => fpga_0_MCB_DDR3_mcbx_dram_cas_n_pin,
fpga_0_MCB_DDR3_mcbx_dram_we_n_pin => fpga_0_MCB_DDR3_mcbx_dram_we_n_pin,
fpga_0_MCB_DDR3_mcbx_dram_cke_pin => fpga_0_MCB_DDR3_mcbx_dram_cke_pin,
fpga_0_MCB_DDR3_mcbx_dram_clk_pin => fpga_0_MCB_DDR3_mcbx_dram_clk_pin,
fpga_0_MCB_DDR3_mcbx_dram_clk_n_pin => fpga_0_MCB_DDR3_mcbx_dram_clk_n_pin,
fpga_0_MCB_DDR3_mcbx_dram_dq_pin => fpga_0_MCB_DDR3_mcbx_dram_dq_pin,
fpga_0_MCB_DDR3_mcbx_dram_dqs_pin => fpga_0_MCB_DDR3_mcbx_dram_dqs_pin,
fpga_0_MCB_DDR3_mcbx_dram_dqs_n_pin => fpga_0_MCB_DDR3_mcbx_dram_dqs_n_pin,
fpga_0_MCB_DDR3_mcbx_dram_udqs_pin => fpga_0_MCB_DDR3_mcbx_dram_udqs_pin,
fpga_0_MCB_DDR3_mcbx_dram_udqs_n_pin => fpga_0_MCB_DDR3_mcbx_dram_udqs_n_pin,
fpga_0_MCB_DDR3_mcbx_dram_udm_pin => fpga_0_MCB_DDR3_mcbx_dram_udm_pin,
fpga_0_MCB_DDR3_mcbx_dram_ldm_pin => fpga_0_MCB_DDR3_mcbx_dram_ldm_pin,
fpga_0_MCB_DDR3_mcbx_dram_odt_pin => fpga_0_MCB_DDR3_mcbx_dram_odt_pin,
fpga_0_MCB_DDR3_mcbx_dram_ddr3_rst_pin => fpga_0_MCB_DDR3_mcbx_dram_ddr3_rst_pin,
fpga_0_MCB_DDR3_rzq_pin => fpga_0_MCB_DDR3_rzq_pin,
fpga_0_MCB_DDR3_zio_pin => fpga_0_MCB_DDR3_zio_pin,
fpga_0_clk_1_sys_clk_p_pin => clkin2,
fpga_0_clk_1_sys_clk_n_pin => fpga_0_clk_1_sys_clk_n_pin,
fpga_0_rst_1_sys_rst_pin => fpga_0_rst_1_sys_rst_pin,
xps_gpio_0_GPIO_IO_I_pin => xps_gpio_0_GPIO_IO_I_pin,
xps_gpio_0_GPIO2_IO_I_pin => xps_gpio_0_GPIO2_IO_I_pin,
xps_gpio_1_GPIO_IO_I_pin => xps_gpio_1_GPIO_IO_I_pin,
xps_gpio_1_GPIO2_IO_I_pin => xps_gpio_1_GPIO2_IO_I_pin,
xps_gpio_2_GPIO_IO_I_pin => xps_gpio_2_GPIO_IO_I_pin,
xps_gpio_2_GPIO2_IO_I_pin => xps_gpio_2_GPIO2_IO_I_pin,
xps_gpio_3_GPIO_IO_I_pin => xps_gpio_3_GPIO_IO_I_pin,
xps_gpio_3_GPIO2_IO_I_pin => xps_gpio_3_GPIO2_IO_I_pin,
xps_gpio_4_GPIO_IO_O_pin => xps_gpio_4_GPIO_IO_O_pin,
xps_gpio_5_GPIO_IO_O_pin => xps_gpio_5_GPIO_IO_O_pin,
xps_gpio_5_GPIO2_IO_O_pin => xps_gpio_5_GPIO2_IO_O_pin,
xps_gpio_6_GPIO_IO_O_pin => xps_gpio_6_GPIO_IO_O_pin,
xps_gpio_6_GPIO2_IO_O_pin => xps_gpio_6_GPIO2_IO_O_pin,
xps_gpio_7_GPIO_IO_O_pin => xps_gpio_7_GPIO_IO_O_pin,
xps_gpio_7_GPIO2_IO_O_pin => xps_gpio_7_GPIO2_IO_O_pin,
xps_gpio_8_GPIO_IO_O_pin => xps_gpio_8_GPIO_IO_O_pin,
xps_gpio_8_GPIO2_IO_O_pin => xps_gpio_8_GPIO2_IO_O_pin
-- clock_generator_0_CLKOUT3_pin => clock_generator_0_CLKOUT3_pin
end architecture STRUCTURE;
-- file: clk_wiz_v3_6.vhd
-- (c) Copyright 2008 - 2011 Xilinx, Inc. All rights reserved.
-- This file contains confidential and proprietary information
-- of Xilinx, Inc. and is protected under U.S. and
-- international copyright and other intellectual property
-- laws.
-- DISCLAIMER
-- This disclaimer is not a license and does not grant any
-- rights to the materials distributed herewith. Except as
-- otherwise provided in a valid license issued to you by
-- Xilinx, and to the maximum extent permitted by applicable
-- law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
-- WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
-- AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
-- BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
-- INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
-- (2) Xilinx shall not be liable (whether in contract or tort,
-- including negligence, or under any other theory of
-- liability) for any loss or damage of any kind or nature
-- related to, arising under or in connection with these
-- materials, including for any direct, or any indirect,
-- special, incidental, or consequential loss or damage
-- (including loss of data, profits, goodwill, or any type of
-- loss or damage suffered as a result of any action brought
-- by a third party) even if such damage or loss was
-- reasonably foreseeable or Xilinx had been advised of the
-- possibility of the same.
-- CRITICAL APPLICATIONS
-- Xilinx products are not designed or intended to be fail-
-- safe, or for use in any application requiring fail-safe
-- performance, such as life-support or safety devices or
-- systems, Class III medical devices, nuclear facilities,
-- applications related to the deployment of airbags, or any
-- other applications that could lead to death, personal
-- injury, or severe property or environmental damage
-- (individually and collectively, "Critical
-- Applications"). Customer assumes the sole risk and
-- liability of any use of Xilinx products in Critical
-- Applications, subject only to applicable laws and
-- regulations governing limitations on product liability.
-- THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
-- PART OF THIS FILE AT ALL TIMES.
-- User entered comments
-- None
-- "Output Output Phase Duty Pk-to-Pk Phase"
-- "Clock Freq (MHz) (degrees) Cycle (%) Jitter (ps) Error (ps)"
-- CLK_OUT1___200.000______0.000_______N/A______220.000________N/A
-- CLK_OUT2___100.000______0.000_______N/A________0.000________N/A
-- "Input Clock Freq (MHz) Input Jitter (UI)"
-- __primary_________200.000____________0.010
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
library unisim;
use unisim.vcomponents.all;
entity clk_wiz_v3_6 is
port
(-- Clock in ports
-- Clock out ports
end clk_wiz_v3_6;
architecture xilinx of clk_wiz_v3_6 is
attribute CORE_GENERATION_INFO : string;
attribute CORE_GENERATION_INFO of xilinx : architecture is "clk_wiz_v3_6,clk_wiz_v3_6,{component_name=clk_wiz_v3_6,use_phase_alignment=false,use_min_o_jitter=false,use_max_i_jitter=false,use_dyn_phase_shift=false,use_inclk_switchover=false,use_dyn_reconfig=false,feedback_source=FDBK_ONCHIP,primtype_sel=DCM_CLKGEN,num_out_clk=2,clkin1_period=5.0,clkin2_period=5.0,use_power_down=false,use_reset=false,use_locked=false,use_inclk_stopped=false,use_status=false,use_freeze=false,use_clk_valid=false,feedback_type=SINGLE,clock_mgr_type=MANUAL,manual_override=false}";
-- Input clock buffering / unused connectors
signal clkin1 : std_logic;
-- Output clock buffering / unused connectors
signal clkfx : std_logic;
signal clkfx180_unused : std_logic;
signal clkfxdv : std_logic;
signal clkfbout : std_logic;
-- Dynamic programming unused signals
signal progdone_unused : std_logic;
signal locked_internal : std_logic;
signal status_internal : std_logic_vector(2 downto 1);
begin
-- Input buffering
clkin1_buf : IBUFG
port map
(O => clkin1,
I => CLK_IN1);
-- Clocking primitive
-- Instantiation of the DCM primitive
-- * Unused inputs are tied off
-- * Unused outputs are labeled unused
dcm_clkgen_inst: DCM_CLKGEN
generic map
(CLKFXDV_DIVIDE => 2,
CLKFX_DIVIDE => 2,
CLKFX_MULTIPLY => 2,
SPREAD_SPECTRUM => "NONE",
STARTUP_WAIT => FALSE,
CLKIN_PERIOD => 5.0,
CLKFX_MD_MAX => 0.000)
port map
-- Input clock
(CLKIN => clkin1,
-- Output clocks
CLKFX => clkfx,
CLKFX180 => clkfx180_unused,
CLKFXDV => clkfxdv,
-- Ports for dynamic phase shift
PROGCLK => '0',
PROGEN => '0',
PROGDATA => '0',
PROGDONE => progdone_unused,
-- Other control and status signals
FREEZEDCM => '0',
LOCKED => locked_internal,
STATUS => status_internal,
RST => '0');
-- Output buffering
CLK_OUT1 <= clkfx;
CLK_OUT2 <= clkfxdv;
end xilinx;
