Should I take into consideration LNA stability factor?
infinite_gbps
Member level 3
I am using an Avago LNA that according to the datasheet is unconditionally stable.
See link: Ultra Low Noise, High Linearity Active Bias Low Noise Amplifier
I have a test board and populated the components for low NF. If I am only interested in a specific band and the stability factor states that it may be potenctial unstable out of band. Should I be concerned?
Also, should I be concerned if it is unstable out of band as well?
Thank you.
young.microwave.eng
Full Member level 3
Re: LNA Stability Factor
hi
for sure you should take care of loading if your LNA is potentially unstable.
plot stability circles in Gamma S and Gamma L plane and and also situate the termination in those planes.then analyze the stability
---------- Post added at 07:33 ---------- Previous post was at 07:31 ----------
hi
see this link too.maybe it can help you:
https://www.edaboard.com/threads/214213/
tony_lth
Advanced Member level 5
Beijing
Or you can use Mu and Mu_prime to analysis the stability factor.
Yes, the LNA should be stable at whole freq band, such as from 10KHz to 26.5GHz.
