sarjumaharaj
Junior Member level 1
- Joined
- Mar 2, 2014
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 148
Here is my code for shift and add multiplier (datapath controller method) Can anyone please see the code and see where I'm going wrong. It just doesn't seem to work.
The datapath is like this Datapath. However I've combined A and Q as prodandmulti in the code. because my professor told me that making product and multiplier individually caused problem while shifting.
I can upload the project file if you would like to test it yourself.
Here is the code. (ignore the codes in comments)
MAIN MODULE:
DATA PATH:
CONTROLLER
ALU
Multiplicant
Product and Multiplicant
MAIN MODULE:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity mainmodule is
port (load , close ,clk : in std_logic;
ext_multiplier, ext_multiplicant : in std_logic_vector (4 downto 1) ;
product : out std_logic_vector ( 8 downto 1)
end mainmodule;
architecture Behavioral of mainmodule is
component controller_shiftaddmul is
port ( clk , load , q0 , close : in std_logic ;
iniq , inib , inia , shift , add : out std_logic -- n counter out std_logic
end component;
component datapath is
port ( clk , add , inia , inib , iniq , shift : in std_logic ;
ext_multiplier , ext_multiplicant : in std_logic_vector (4 downto 1);
q0 : out std_logic ;
product : out std_logic_vector (8 downto 1)
end component;
signal Sq0 , Sinia,Sinib,siniq,Sshift, Sadd : std_logic ;
--sq0 signal that checks the LSB of Q to see whether we need to shift or add
-- sinia b and q initilizes a b and q here a and q refer to the same component but
-- sinia initializes the last 8 digit and siniq the first 4 digit seee the product mul component it will be clear
-- sshift sadd is shift and add signal
begin
datapath1 : datapath port map (clk , sadd, sinia, sinib, siniq, sshift, ext_multiplier, ext_multiplicant , sq0 , product);
controller1 : controller_shiftaddmul port map (clk ,load, sq0, close , siniq, sinib ,sinia, sshift ,sadd);
end Behavioral;
DATA PATH:
library IEEE;
entity datapath is
end datapath;
architecture Behavioral of datapath is
--component q_multiplier is
-- port ( a0 , clk, shift , ini : in std_logic ;
-- mul: in std_logic_vector ( 4 downto 1);
-- q0 : out std_logic ;
-- temp_out : out std_logic_vector (4 downto 1)
--end component ;
--component a_product is
-- port (add , shift , ini ,clk : in std_logic ;
-- in_prod: in std_logic_vector ( 4 downto 1);
-- out_prod: out std_logic_vector ( 4 downto 1);
-- a0: out std_logic );
--end component;
component prodandmulti is
port (clk ,add, inia, iniq , shift : in std_logic ;
multi : in std_logic_vector (4 downto 1 );
a_in : in std_logic_vector (4 downto 1) ;
A_OUT : out std_logic_vector ( 4 downto 1);
q0: out std_logic ;
output : out std_logic_vector ( 8 downto 1) );
end component;
component ALU is
port (multiplicant , product : in std_logic_vector ( 4 downto 1);
add , clk : in std_logic ;
Aluout : out std_logic_vector (4 downto 1 )
end component;
component b_multiplicant is
port (add ,ini ,clk : in std_logic ;
in_multiplicant : in std_logic_vector (4 downto 1) ;
out_multiplicant: out std_logic_vector (4 downto 1)
end component;
-- DONT SEE THE CODES IN COMMENTS:
-- prod_ALU output from the ALU after adding
-- q0_control signal from the prodandmulti that goes to the controller basically the LSB of Q
-- b_multi multiplicant that goes to ALU
-- prod_A is the product term that goes to the ALU for processing
signal prod_ALU , prod_A: std_logic_vector (4 downto 1); -- ALU BATA MULTIPLIER MA JANEY SIGNAL RA ALU MA JANEY SIGNAL
--signal A_shift : std_logic ;
signal q0_control: std_logic;
signal B_multi : std_logic_vector (4 downto 1);
--signal multiplier_output : std_logic_vector ( 4 downto 1); -- i dont know if this is required
--signal a_product_out : std_logic_vector (4 downto 1);
begin
--A_shift <= a0;
--multiplier:q_multiplier port map (A_shift , clk , shift, iniq, ext_multiplier,q0_control, multiplier_output);
--product1 : a_product port map (add , shift , inia , clk , prod_ALU, prod_A, A_shift );
ALU1: ALU port map ( B_multi,prod_A, add, clk ,prod_ALU );
multiplicant: b_multiplicant port map (add , iniq, clk , ext_multiplicant , B_multi );
promul1 : prodandmulti port map (clk , add ,inia , iniq, shift , ext_multiplier , prod_ALU, prod_A , q0_control , product);
q0 <= q0_control;
end Behavioral;
CONTROLLER
library IEEE;
use ieee.std_logic_unsigned.all;
entity controller_shiftaddmul is
end controller_shiftaddmul;
architecture Behavioral of controller_shiftaddmul is
type state_type is (start , loader , hold , addition , shiftrt , counter , closed ) ;
signal sreg , snext : state_type ;
--sreg is the present state
--snext is the next state
--at each rising edge the next state is copied to present state
signal sigN : std_logic_vector (3 downto 1);
begin
process (clk )
begin
sigN <= "100";
if (clk'event and clk = '1' ) then
sreg <= snext ;
end if ;
end process ;
process (sreg )
begin
case sreg is
when start => inib <= '0' ;
iniq <= '0' ;
--loada <= <= '0';
inia <= '0';
sign <= "000";
shift <= '0';
add <= '0';
if (load = '1') then
snext <= loader ;
else
snext <= start ;
end if ;
when loader => inib <= '1' ;
iniq <= '1' ;
--loada <= <= '0';
inia <= '1';
sign <= "100";
shift <= '0';
add <= '0';
snext <= hold ;
when hold => inib <= '0' ;
iniq <= '0' ;
--loada <= <= '0';
inia <= '0';
--sign <= "10000"; -- esko value k huncha khai kunni
shift <= '0'; -- i think sign is not required as it is a variable so change of state most likely
add <= '0'; --wont affect the value
if (q0 ='0') then
snext <= shiftrt ;
else
snext <= addition ;
end if ;
when addition => inib <= '0' ;
iniq <= '0' ;
--loada <= <= '1'; -- i think load a is not requred as there is already add signal which will do its work
inia <= '0';
--sign <= "10000";
shift <= '0';
add <= '1';
snext <= shiftrt ;
when shiftrt => inib <= '0' ;
iniq <= '0' ;
inia <= '0';
--sign <= "10000";
shift <= '1';
add <= '0';
snext <= counter ;
when counter => sign <= sign - 1;
if ( sign /= "000") then
snext <= hold ;
else
if (close = '1') then
snext <= closed ;
else
snext <= start ;
end if ;
end if ;
when others => snext <= start ;
end case ;
end process ;
end Behavioral;
ALU
library IEEE;
entity ALU is
end ALU;
architecture Behavioral of ALU is
signal temp : std_logic_vector ( 4 downto 1);
begin
process (clk)
begin
if rising_edge(clk) then
if (add = '1' ) then
temp <= multiplicant + product ;
end if;
aluout <= temp ;
end if ;
end process ;
end Behavioral;
Multiplicant
library IEEE;
entity b_multiplicant is
end b_multiplicant;
architecture Behavioral of b_multiplicant is
signal temp_multiplicant : std_logic_vector ( 4 downto 1) ;
begin
process (clk , ini , add)
begin
if (rising_edge(clk)) then
if (ini = '1' ) then
temp_multiplicant <= in_multiplicant;
end if ;
out_multiplicant <= temp_multiplicant ;
end if ;
end if ;
end process ;
end Behavioral;
-- REPORT --
-- Once the first condition is run the second condition will give output
-- But once the second condition is run it will give output regardless
--of whether the second condition is false in the next clock cycle
library IEEE;
entity prodandmulti is
q0: out std_logic ;
end prodandmulti;
architecture Behavioral of prodandmulti is
signal promul : std_logic_vector ( 8 downto 1) ;
signal signal_q0: std_logic ;
begin
process (clk )
begin
if (inia = '1' ) then
promul (8 downto 5) <= "0000" ;
end if ;
if (iniq = '1') then
promul (4 downto 1) <= multi ;
end if ;
signal_q0 <= promul(1);
if (shift = '1' ) then
for i in 7 downto 1 loop
promul(8-i) <= promul(9-i) ;
end loop ;
promul(8) <= '0' ;
end if ;
--end if ; -- here end if is at the last
if ( add = '1' ) then
a_out <= promul(8 downto 5) ;
promul ( 8 downto 5)<= a_in ;
end if ;
q0 <= signal_q0;
output <= promul ;
end if ;
end process ;
end Behavioral;
