1. What happens if we give a high value for set_transition_delay -min and a low value to set_transition_delay -max ?? Simply if max transition delay is less than min transition delay , what would the tool do ?
2. What happens if I give a negative transition time , how would synopsys DC handle it ?
You could try it out with a toy example and find out. I can't understand how a signal can have a negative transition time. Slopes are either perfect (0 timing) or have a positive transition.
