serial to parallel converter using state machine
Junus2012
Advanced Member level 5
Italy
Dear friends
I writing a code for serial to parallel converter, the serial data consist of 10 bits, (start bit, 7 data bits, parity bit, end bit).. the conversion starts when the start bit is one and ended with end bit.
I used the state machine for reading the data in sequence and at the end put all them together in a register and show them at the output.
The problem I getting is that my state machine stop at state seven (which is related to data seven of the input), after that the state machine goes to the first state which i named it idle and ignores the state eight, nine.
if you look on to my code you will see im clearly put the condition to go state eight after seven or nine after eight,, but I cant find any reason that makes those states doesnt appear.
Please I need your kind help and any suggestion will be very appreciated.
thank you very much;
below is my code
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity spc_state is
    Port ( clk : in  STD_LOGIC;
           rst : in  STD_LOGIC;
           d_in : in  STD_LOGIC;
           ready : out  STD_LOGIC:='0';
           err : out  STD_LOGIC:='0';
           d_out : out  STD_LOGIC_VECTOR (6 downto 0):="0000000");
end spc_state;
architecture Behavioral of spc_state is
type state is (idle, one, two, three, four, five, six, seven, eight, nine);
signal pres_state, next_state : state;
signal reg : std_logic_vector (9 downto 1);
begin
process (clk, rst)
begin
if (rst = '1')then
pres_state <= idle;
elsif (clk' event and clk = '1') then
pres_state <= next_state;
end if;
end process;
process (pres_state, d_in)
begin
next_state <= pres_state;
case pres_state is
when idle => if d_in = '1' then
                next_state <= one;
                 else next_state <= idle;
                 end if;
when one => reg(1)<= d_in;
            next_state <= two;
when two => reg(2)<= d_in;
            next_state <= three;
when three => reg(3)<= d_in;
            next_state <= four;
when four => reg(4)<= d_in;
            next_state <= five;
when five => reg(5)<= d_in;
            next_state <= six;
when six => reg(6)<= d_in;
            next_state <= seven;
when seven => reg(7) <= d_in;
            next_state <= eight;
when eight => reg(8) <= d_in;
             next_state <= nine;
when nine => reg(9) <= d_in;
             next_state <= idle;
when others => next_state <= idle;
end case;
end process;
process (pres_state)
variable temp : std_logic:='0';
variable temp2: std_logic_vector(7 downto 1):="0000000";
begin
case pres_state is
when idle => temp := reg(1) xor reg(2) xor reg(3) xor reg(4) xor reg(5) xor reg(6) xor reg(7) xor reg(8) xor reg(9);
             err <= temp;
             if temp = '0' then
                    ready <= '1';
             d_out <= reg(7 downto 1);
                 temp2 := reg(7 downto 1);
                 end if;
when others => d_out <= temp2;
end case;
end process;
end Behavioral;
I can't confirm the observation. The present code goes through all nine states after a '1' data input.
If the code is intended as an UART design, it's missing a number of things.
Dear Fvm
nice to see you again, its been long time :)
First thank you for your response
logically, there is no obvious or clear reason so the machine doesnt go to the eight or nine state,,, I got another confermation of the mistake,,, in the reset I have assigned the state to nine, but again it doesnt show nine, directly show idle rather..
As you said, im trying to use code in UART, kindly could you tell me please what is missing,, if you have some material about it with vhdl then plz it also help
many thanx :)
The "rst" input can send the state machine back to idle at any time if it is active. (If the rst code is correct). Anything going on with rst?
hii
no no, the rst is not working well if i assign it to states from one to seven but eight and nine doesnt work with rst
Dear Fvm
many thanx :)
hii
sorry for the dumb question, but how do you know what states are taken ?
are you doing some simulation or using chipscope or logic analyser ?
mabee it actually works ...
im checking it by simulation
your suggestion is not dump, because sometimes i see some of my design work practically but not by simulation,, hope this will be the same case
I believe that you simulated a different code than that in post #1, because I don't see the said problem.
For a full operational UART design you need a baud rate generator, oversampling of input data, check for valid start bit after a half bit period.
mabe your simulation time resolution is too low ?
if you have modelsim you need to :
vsim -t ps
