serial to Ethernet device
drbizzarow
Advanced Member level 1
serail to ethernet microchip
hi to all..
i want to send my microcontroller serial data through ethernet to a remote PC(in same network).any link, tutorial, book or else you can do.
your guidence will be very helpful to me.....
BEST REGARDS.
project rtl8019 virtual serial
hi
ive used the drivers here for comvdd and it worked
i used trsansmit from a master via the lan driver to another machine also running the same driver
and was able to control a proteus session over lan
infact several machine all listening on the same port
https://www.virtual-serial-port.com/
look down the page to the bottom for network serial driver
microchip serial to ethernet
thx for your help VSMDVDD ....
i wan to send my microcontroller data throught ethernet where at the one node there is no pc but my microcotroller is atteched .
trsansmit serial
Hey drbizzarow
If you are using a PIC micro or similar, I would recommend using the ethernet controller from Microchip (ENC28J60 - SMD or PDIP - https://ww1.microchip.com/downloads/en/DeviceDoc/39662b.pdf)
It uses a SPI interface at the PIC-side, and very few other components.
- or maybe a PIC with integrated ethernet controller like the PIC18F87J60 (SMD only :-( https://ww1.microchip.com/downloads/en/DeviceDoc/39762c.pdf )
An alternative could be a Realtek ethernet controller (RTL8019AS) - also lot of online information.
Which language do you prefer?
Microchip got a free TCP/IP stack writen in C18 (supports HiTech C also as far as I remember) - very usefull as it would be a nightmare to do it yourself. The stack shows how to make a lot of things, like http, ftp, tftp and snmp - and controlling the internal hardware in the PIC by these interfaces.
As far as I know there isn't any microchip driver for a "virtual ethernet comport" for windows XP, but maybe your application could be just as useful with a http interface?
You could use the stack to send simple packages to a PC, but how you easy can capture them i don't know - maybe some MATLAB or C++ could keep it simple.
Good luck (this i properly not a beginners project - I tried it and haven't succeeded yet - maybe a demoboard isn't such a bad idea - approx. 165 USD from Microchip)
HPW123 (20 yo - PIC noob)
using pic18f87j60 for ethernet project
thx pal for all helps ...
im using CSS c compiler .
pic18f87j60 proteus
Take a look at the Serial Ethernet Board by mE:
