Register Log in
Serial Communication - 10KM range
Sobakava
Full Member level 6
I need to form a serial communication between two points and looking for a solution. First I thougt convert my uart Rs232 to RS485 but this is limited with 1.2KM without repeaters. I can not use repeaters because the wires will be buried into ground with a pipe with 2.5m radius.
I also thought about wireless connection but the nodes are not in line of sight.
Any recommendations? Is there a transceiver which is capable of transmitting 9600bit/s serial data over regular / twisted pair wires?
This connection is very cost sensitive so I do not want to use expensive and special devices etc.
Thanks
IanP
Advanced Member level 5
West Coast
For that distance (10km) you have to consider optical fibre (Single-Mode) ..
Not only it provides noiseless, reliable data link but it is also cost effective ..
And 9600 baud is not a problem ..
eg.
http://www.ucs.co.uk/index.php?pid=943
Rgds,
IanP
Sobakava
Full Member level 6
Edit after I got price quotation for wires and wire mounting service costs :) :
I want to do this with wireless communication. The points are not in line of sight, there is a small peak between nodes. How can I form reliable wireless serial communication between those two points? 9600bps is fairly enough...
angelote
Spain
Learn about WiMax.
It is similar to WiFi, but in theory allows 48km links at 70Mbps, and doesn't need direct sight.
I don't know about cost, and you'll need some intelligent devices.
You will need two serial to ethernet converters, an two WiMAX access points to establish the link.
dani
Full Member level 4
UK
Why not GSM/GPRS/SMS ...?
Also Normall telephone line with 56K Fax modem is another option if you dont want to go for wirless...
Dani
TekUT
Full Member level 6
Italy
You can try with serial to Ethernet embedded device (like the TIBBO EM200) and use external repeater, but I've no idea about the overall cost.
Bye
Pow
