sequence detector fsm
if i remember correctly, then Prof. Srinivasan in this lecture, implements
twice this sequence detector... The one of the two implementations he talks
about is the one you are interested in... I believe that it should be best for you
if you carefully watch this presentation and then come up with a solution.
We will help you understand this way what you think wrong and what right.
By just giving you a solution it will not help you... This is my view....
Pavlos
