tuhin.neogi
Newbie level 1
Sentaurus Problem - Running "sdevice" for coupled electrical and optical problem
Hi All,
I am running sentaurus to simulate a device for both electrical and optical models.
My Electrical grid is created in .tdr and .grd forms ( I can use either one). Then I put this electrical grid and doping files as an input to my waveguide_des.cmd file.
In my waveguide_des.cmd file I have a physics section which runs Laser() command with all the necessary details. IN the solve section I have
Coupled { Poisson Electron Hole PhotonRate }
which I think enables both electrical and optical simulations.
When I run the following command on this file ---- "sdevice waveguide_des.cmd".
I get this error as posted below:
Reading geometry 'waveguide_msh.grd' ...
done.
WARNING: Cannot open input file devtype.txt : using default device (Laser). Laser is 0, SOA is 1, WPD is 2 .
Setting up (3D) mode solver ...
The following auxiliary device instances for solving the 3D optical problem have been created:
done.
Cannot open file: msdbr_laser.dat
If I remove the laser section and solve only electrical problem I dont get any error.
Any help suggestions will be greatly appreciated.
Thanks in advance
Tuhin
Hi All,
done.
done.
Thanks in advance
Tuhin
