ritu.vlsi
Newbie level 3
I want to send values of two matrix from two seperate .txt files to Spartan 3 starter FPGA kit through RS232 cable after that I want to add those matrix.Resultant matrix will be shown from hyperterminal.
I have already designed the hardware using MicroBlaze Processor in xilinx edk 10.1i and made the connection between PC to FPGA using RS232 During this process I am getting a C file as shown below before generating the bit file,
* Your XPS project directory is at:
* C:\sankha\
// Located in: microblaze_0/include/xparameters.h
#include "xparameters.h"
#include "stdio.h"
#include "xutil.h"
int main (void) {
* Enable and initialize cache
#if XPAR_MICROBLAZE_0_USE_ICACHE
microblaze_init_icache_range(0, XPAR_MICROBLAZE_0_CACHE_BYTE_SIZE);
microblaze_enable_icache();
#endif
#if XPAR_MICROBLAZE_0_USE_DCACHE
microblaze_init_dcache_range(0, XPAR_MICROBLAZE_0_DCACHE_BYTE_SIZE);
microblaze_enable_dcache();
#endif
print("-- Entering main() --\r\n");
* MemoryTest routine will not be run for the memory at
* 0x00000000 (dlmb_cntlr)
* because it is being used to hold a part of this application program
* Disable cache and reinitialize it so that other
* applications can be run with no problems
microblaze_disable_dcache();
#endif
microblaze_disable_icache();
#endif
print("-- Exiting main() --\r\n");
return 0;
After generating bitfile & downloading it I can see the output in hyperterminal as "Exiting main() Exiting main()" what C code I have to put to get the matrix addition result which will be shown in hyperterminal. Pls reply me!!!!!!
* C:\sankha\
#include "stdio.h"
#include "xutil.h"
int main (void) {
#endif
#endif
#endif
#endif
return 0;
