SD-RAM signal connection to ZYNQ
engr_joni_ee
Advanced Member level 3
Hi, I am using SD-RAM (MT41K256M16) with ZYNQ 7030 in a test board PCB layout. I have question regarding the following signals at the SD-RAM side. How should they be connected to the ZYNQ and which pins in PS BANK 502 in ZYNQ ?
  • LDM and UDM
  • LDQS, LDQS #
  • UDQS, UDQS #
Hi, Now I have found signal connections but I am wondering about some signals (RAS#, CAS#, WE#). What are these signals for ?
RAS# row address strobe
CAS# column address strobe
WE# write enable
These three bits are used as commands for the various operations that are performed by the SDRAM. The order in which the signals toggle can determine what mode the SDRAM is in. You need to read a DDR3 SDRAM datasheet to understand how the signals control the transfers. It's a bit too much to copy to the forum.
