Schmitt input for xilinx's spartan2 design.
zcq
Full Member level 1
Anybody know is it possible to set the schmitt input for spartan2 fpga?
I can not find it in the databook. If not,why?
Thanks a lot!
Any comment is welcome. Thanks!
zcq,
what do you mean with schmitt inputs? schmitt-triggered inputs that might be used to debounce your input signal(s)?? If you need to debounce your signal, try to use shiftregisters that "detect" your edges and logical state of the signal (as far I remember there is some additional register available too in near of the pad, but I'm not sure)
Hope it helped,
Maddin
Yes, i want to set the input signal pad as schmitt-triggered to act as a debouncer. Is it possible?
I haven't used this feature yet, but I think it should be possible by editing the ucf (user constraint file) or passing some attribute in your HDL code ;
please check the docu or maybe somebody else can help you, sorry for any inconvenience.
Maddin
Have a look at :
I m not sure but i think that in constrains you can make it work, there you have some options like registered inputs or outputs i dont remember exatly.
by people.
Is it at all possible to configure Spartan II-IOBs as schmitt triggers? I don't think so!
I think the inputs are by definition kind of shmit triggers, as you can set input levels to TTL or CMOS. a '1' is detected for a certain analogue level, which isn't the same as a '0'.
But if you want to debounce a signal digitaly for a switch, a shmit trigger is not what you need, as the input signal will go from high to low several times. a simple way to do it is is use register with a slow clock
process(clk)
if clk'event and clk='1' then
registered_1<=input;
registered_2<=registered_1;
output<=registered_1 and registered_2 and input
end if;
end process;
