schematic which is Powerlogic5.0 format - how to open it
fireman
Junior Member level 2
Emergency!
My friend sent me a schematic which is Powerlogic5.0 format, I need to open it but I don't have this tool. Anyone tells me where I can download Powerlogic5.0? Thanks, Thanks!!!
Hello, fireman
Unfortunately, you can't download the powerlogic5.
In case of the powerlogic5, there are no domo's or eval version,
only inside of purchased.
You only can get it inside of purchased CD's, it only suppled through CD.
Detailed informations you can read at montor@s web.
Good luck.
:roll:
Powerlogic5.01?
Thanks.
I have tried Powerlogic5.01, but it needs to be installed in Powerlogic5.0 directory, nothing can be done to solve the problem?
Is there any other versions of Powerlogic for download?
Be attention, because on installation proccess is possible to change the directory to install the application, but you can not install on directories with space on name.
eg. C:/power logic is wrong,
eg. C:/powerlogic is right.
Perhaps, you can download power logic 4.0 on another site, but your best bet is 5.0.
