Schematic in Pdf form to be converted to Orcad cis
Rame
Full Member level 6
BANGALORE
pdf to schematic converter
Hi Folks,
I have schematic in Pdf form,now i need to capture the schematic in orcad cis ver 16,i had asked for Bom,datasheet and netlist for the same from the concerned person,but then he denied.
Is there any way to convert the pdf to schematic form or am i missing out something along on the inputs to ask...
Suggestion,advices and insights are appreciated.
Thanks & Best Regards,
Ramesh
schematic to pdf
If you mean Adobe PDF - you can't convert that to a schematic. It's just a picture of the schematic and contains no net information or component information.
If your file is a PCAD PDIF file ( they have a PDF file extension), then you can convert that to Orcad.
pdf 2 orcad
The netlist can be generated after you successfully converted the schematic (or drew it).
(Above two reply already explain), however in addtion to that you just use PDIF-IN command to open the file, if it is a valid PDIF-OUT file.
As Far as BOM is concerned you have to write it manually (its been quite long to use Orcad so I do not remember now) however in Altium Designer you can generate BOM through software.
ENJOY!
read pdf schematic by program
i haven't seen any tool,where u can create schematic from PDF file.
I hope your customer is new and not aware with the design practices.
