philcorb
Junior Member level 3
- Joined
- Jun 30, 2011
- Messages
- 25
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Trondheim, Norway
- Activity points
- 1,451
I currently run process corners using custom made batch scripts for Eldo. The scripts add the library paths and parameter setup to the start of a .cir file. I then run the all the .cir file varients and extract/sort the results. I have looked at using the .alter command but it seems to not always compute a new operating point for each run. This can lead to convergence problems.
Does anyone run corners using Eldo in a different way? Do you have any suggestions for different approaches?
