RTL Design from timing diagram
hm1622
Junior Member level 1
surat
I dont know from where to start so guys help me with that. i am beginner in RTL design
please help me with RTL(verilog) design of this block.i have some specification
like
• X means a minimum size width for n and p channel transistor width for
the transistors inside the inverter .
• 8X means n and p ch widths are 8 times that of 1X inverter.
• D<9:0> means data lines; these are digital outputs that change after the clock rising edge. Think of it as a digital bus.
If you don't know where to start, and you certainly have not explained where you need to finish, how can we possibly give you instructions from start to finish?
D is suppoed to change to wHAT?
Your specification seems incomplete.
What is the relation of the outputs to inputs? Do you have to design the inverters first and then use them in your RTL or do you already have the standard cells?
Once you have the complete spec you can start the RTL coding which is followed by synthesis and place & route.
A & B = Asynchronous Digital control inputs
X = a minimum size width for n and p channel transistor width for
the transistors inside the inverter.
8X = n and p channel widths are 8 times that of 1X inverter.
D<9:0> = data lines; these are digital outputs that change *after*
I will try to help but as others have said, your spec is still unclear.
The 1st two points indicate the design of an inverter, for which you need some SPICE tool. You do such exercises typically in the university for very basic CMOS Analog design lab assignments. This has no relation to RTL design.
So I find your statement contradictory - " i am beginner in RTL design please help me with RTL(verilog) design of this block".
I also don't understand any of your attachments. Digital design (RTL) specs are not distributed in this way!
Ask yourself these questions:
What am I trying to achieve?
What are my inputs and what should be the desired outputs, get the proper spec/lab exercise/assignment/handout if you don't have?
Do I need to do an analog design or digital design?
Reactions: FvM
    FvM
