MANO.5
Member level 1
- Joined
- Mar 15, 2013
- Messages
- 36
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,618
hai friends,
I am new to embedded field. I have working circuit with 8051-micro and ds1307 rtc with time set function.But it was not working properly.when starting rtc it give correct time.Then rtc time will decreases than actual time.crystal for microcontroller -12Mhz and for-DS1307 is 32.768khz.Circuit Diagram is
please help anybody.as soon as possible
my code is
my code is
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 #include<reg51.h> #include<ds1307.h> #include<string.h> sbit rs=P1^0; sbit rw=P1^1; sbit en=P1^2; sbit sda_rtc =P1^3; sbit scl_rtc =P1^4; sfr ldata=0xA0; //p2 sfr KEYPRT=0xB0; // Port for keypad sbit ROW0 = P3^4; sbit ROW1 = P3^5; sbit ROW2 = P3^6; sbit ROW3 = P3^7; sbit COL0 = P3^0; sbit COL1 = P3^1; sbit COL2 = P3^2; sbit COL3 = P3^3; DS1307_get(unsigned char); unsigned char KEYGET(void); void lcdcommnd(unsigned char value); void lcddata(unsigned char value); void lcd_putc(unsigned char ascii); void MSDelay(int ms); void LcdLine1(unsigned char *value); void LcdLine2(unsigned char *value); send2lcd(unsigned char value); unsigned int Rtc_add_wr,Rtc_add_rd; unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc; void MSDelay(int ms) { unsigned int i,j; for(i=0;i<ms;i++) { for(j=0;j<1275;j++); } } void lcdcommnd(unsigned char value) { ldata= value; rs= 0; rw=0; en=1; MSDelay(1); en=0; return; } void lcddata(unsigned char value) { ldata = value; rs= 1; rw=0; en=1; MSDelay(1); en=0; return; } void lcd_string(unsigned char *value) // Function to send string to LCD { int x; for(x=0;value[x]!=0;x++) { lcddata(value[x]); } } void lcd_init() { lcdcommnd(0x38); MSDelay(100); lcdcommnd(0x0e); MSDelay(100); lcdcommnd(0x01); MSDelay(100); } void lcd_decimal2(unsigned char val) { unsigned char d,d1,d2; d=val%100; d1=d/10; d2=d%10; lcddata(d1+48); lcddata(d2+48); } send2lcd(unsigned char value) { unsigned char buf1,buf2,buf = 0; buf1 = value & 0xF0; /* Filter for high byte */ buf1 = (buf1>>4); /* Convert to ascii code */ buf2 = value & 0x0F; /* Filter for low byte */ buf=(buf1*10)+buf2; return buf; } unsigned char KEYGET() { unsigned char colloc, rowloc, keyvalue; unsigned char keypad[4] [4] = {'0', '1', '2','3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'}; do { ROW0 = 0; ROW1 = 0; ROW2 = 0; ROW3 = 0; // ground all rows colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits } while ( colloc != 0X0F); // check until all keys released do { do { MSDelay(5); colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits } while ( colloc == 0X0F); //keep checking for keypress MSDelay(5); //delay for debounce colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits } while ( colloc == 0X0F); //keep checking for keypress while (1) { ROW0 = 0; // ground row0 ROW1 = 1; ROW2 = 1; ROW3 = 1; colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits if( colloc!=0x0F) { rowloc = 0; break; } ROW0 = 1; // ground row1 ROW1 = 0; ROW2 = 1; ROW3 = 1; colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits if( colloc!=0x0F) { rowloc = 1; break; } ROW0 = 1; // ground row2 ROW1 = 1; ROW2 = 0; ROW3 = 1; colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits if( colloc!=0x0F) { rowloc = 2; break; } ROW0 = 1; // ground row3 ROW1 = 1; ROW2 = 1; ROW3 = 0; colloc = KEYPRT; // read port0 colloc &= 0x0F; //mask used bits rowloc = 3; break; } if( colloc ==0x0E) keyvalue = keypad [rowloc] [0]; else if ( colloc ==0x0D) keyvalue = keypad [rowloc] [1]; else if ( colloc ==0x0B) keyvalue = keypad [rowloc] [2]; else keyvalue = keypad [rowloc] [3]; return (keyvalue); } void Rtc_Start()// must for any operation on EEPROM { sda_rtc=1; scl_rtc=1; sda_rtc=0; scl_rtc=0; } void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation { sda_rtc=0; scl_rtc=1; sda_rtc=1; } void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over { sda_rtc=1; scl_rtc=1; scl_rtc=0; } void Rtc_Rx()// program read the data from the EEPROM { unsigned char l_rtc; sda_rtc=1; for (l_rtc=0;l_rtc<=7;l_rtc++) { scl_rtc=1; in_rtc=in_rtc<<1; in_rtc|=sda_rtc; scl_rtc=0; } datain_rtc=in_rtc; in_rtc=0; } void Rtc_Tx()// program to send the device address, read/write address,data to be written { signed char i_rtc; for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char. { CY=(d_rtc>>i_rtc)&0x01; sda_rtc=CY; scl_rtc=1;// clock is essential inorder to write or read scl_rtc=0;// clk should be alternated } sda_rtc=1; scl_rtc=1; CY=sda_rtc; scl_rtc=0; } void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken { Rtc_Start(); here1: d_rtc=Rtc_add_wr;// device address is passed Rtc_Tx(); if(CY==1)goto here1; again1: d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed Rtc_Tx(); if(CY==1)goto again1; } Rtc_Read(unsigned char zig)// program to read from EEPROM { dat_rtc=zig; Rtc_rd_wr_sub(); Rtc_Start(); be: d_rtc=Rtc_add_rd; Rtc_Tx(); if(CY==1)goto be; Rtc_Rx(); Rtc_Ack(); CY=0; Rtc_Stop(); return(datain_rtc); } DS1307_get(unsigned char addr) { unsigned char ret; Rtc_Start(); ret = Rtc_Read(addr); Rtc_Stop(); return ret; } void Rtc_Init()//lower order 256 bytes of the chip { Rtc_add_wr=0xd0; Rtc_add_rd=0xd1; } void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM { dat_rtc=zig; temp_rtc=zag; Rtc_rd_wr_sub(); above: d_rtc=temp_rtc; Rtc_Tx(); if (CY==1)goto above; CY=0; Rtc_Stop(); } void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss) { Rtc_Start(); Rtc_Write(0x00,ss); /* Write sec on RAM address 00H */ Rtc_Write(0x01,mm); /* Write min on RAM address 01H */ Rtc_Write(0x02,hh); /* Write hour on RAM address 02H */ Rtc_Stop(); /* Stop i2c bus */ } void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy) { Rtc_Start(); Rtc_Write(0x04,dd); /* Write date on RAM address 04H */ Rtc_Write(0x05,mm); /* Write month on RAM address 05H */ Rtc_Write(0x06,yy); /* Write year on RAM address 06H */ Rtc_Stop(); /* Stop i2c bus */ } void main() { unsigned int y,tens,ones; unsigned char sec, min, hour, date, month, year; //unsigned char a,b,c,d,e,hr1,hr2,sec1,sec2,min1,min2,dt1,dt2,mon1,mon2; lcd_init(); MSDelay(200); Rtc_Init(); lcdcommnd(0x80); lcd_string("1->SET DATE&TIME"); lcdcommnd(0xC0); lcd_string ("Any other-> SKIP"); COL0 = 1; // make cols input port COL1 = 1; COL2 = 1; y = KEYGET(); lcdcommnd(0x01); // Clear Command MSDelay(20); lcddata(y); MSDelay(20); if (y == '1') { lcdcommnd(0x01); lcdcommnd(0x80); lcd_string("HR:MN:SC"); ////////////////hour///////////////////// y = KEYGET(); tens = y & 0x0F; tens = (tens << 4) & 0xF0; lcdcommnd(0XC0); lcddata(y); y = KEYGET(); ones = y & 0x0F; lcdcommnd(0XC1); lcddata(y); hour = (tens |ones ); lcdcommnd(0XC2); lcddata(':'); ////////////////min///////////////////// y = KEYGET(); tens = y & 0x0F; tens = (tens << 4) & 0xF0; lcdcommnd(0XC3); lcddata(y); y = KEYGET(); ones = y & 0x0F; lcdcommnd(0XC4); lcddata(y); min = (tens |ones ); lcdcommnd(0XC5); lcddata(':'); ////////////////sec///////////////////// y = KEYGET(); tens = y & 0x0F; tens = (tens << 4) & 0xF0; lcdcommnd(0XC6); lcddata(y); y = KEYGET(); ones = y & 0x0F; lcdcommnd(0XC7); lcddata(y); sec = (tens |ones ); /////////////////////////////////////// MSDelay(20); //////////////////////////////////////////// lcdcommnd(0x01); // Clear Command MSDelay(20); lcdcommnd(0x80); lcd_string("DD:MM:YY"); ////////////////date///////////////////// y = KEYGET(); tens = y & 0x0F; tens = (tens << 4) & 0xF0; lcdcommnd(0XC0); lcddata(y); y = KEYGET(); ones = y & 0x0F; lcdcommnd(0XC1); lcddata(y); date = (tens |ones ); lcdcommnd(0XC2); lcddata(':'); //////////////////month///////////////// y = KEYGET(); tens = y & 0x0F; tens = (tens << 4) & 0xF0; lcdcommnd(0XC3); lcddata(y); y = KEYGET(); ones = y & 0x0F; lcdcommnd(0XC4); lcddata(y); month = (tens |ones ); lcdcommnd(0XC5); lcddata(':'); /////////////////////////////////////// //////////////////year///////////////// y = KEYGET(); tens = y & 0x0F; tens = (tens << 4) & 0xF0; lcdcommnd(0XC6); lcddata(y); y = KEYGET(); ones = y & 0x0F; lcdcommnd(0XC7); lcddata(y); year = (tens |ones ); /////////////////////////////////////// ///////////////////////////////////////// DS1307_settime(hour,min,sec); /* Set Time (hh:mm:ss) */ DS1307_setdate(date,month,year); /* Set Date (dd/mm/yy) */ MSDelay(200); lcdcommnd(0x01); // Clear Command lcdcommnd(0x80); lcd_string("Date:"); lcdcommnd(0xC0); lcd_string("Time:"); sec = DS1307_get(0x00); min = DS1307_get(0x01); hour = DS1307_get(0x02); date = DS1307_get(0x04); month = DS1307_get(0x05); year = DS1307_get(0x06); sec=send2lcd(sec); min=send2lcd(min); hour=send2lcd(hour); date=send2lcd(date); month=send2lcd(month); year=send2lcd(year); lcdcommnd(0x80); lcd_string("Date:"); lcdcommnd(0xC0); lcd_string("Time:"); lcdcommnd(0x85); lcd_decimal2(date); lcdcommnd(0x87); lcddata('/'); lcdcommnd(0x88); lcd_decimal2(month); lcdcommnd(0x8A); lcddata('/'); lcdcommnd(0x8B); lcd_decimal2(year); lcdcommnd(0xC5); lcd_decimal2(hour); lcdcommnd(0xC7); lcddata('.'); lcdcommnd(0xC8); lcd_decimal2(min); lcdcommnd(0xCA); lcddata('.'); lcdcommnd(0xCB); lcd_decimal2(sec); MSDelay(100); } while(1) { lcdcommnd(0x01); /////////////////////////////rtc/////////////////////////////// Rtc_Init(); sec = DS1307_get(0x00); min = DS1307_get(0x01); hour = DS1307_get(0x02); date = DS1307_get(0x04); month = DS1307_get(0x05); year = DS1307_get(0x06); sec=send2lcd(sec); min=send2lcd(min); hour=send2lcd(hour); date=send2lcd(date); month=send2lcd(month); year=send2lcd(year); lcdcommnd(0x80); lcd_string("Date:"); lcdcommnd(0xC0); lcd_string("Time:"); lcdcommnd(0x85); lcd_decimal2(date); lcdcommnd(0x87); lcddata('/'); lcdcommnd(0x88); lcd_decimal2(month); lcdcommnd(0x8A); lcddata('/'); lcdcommnd(0x8B); lcd_decimal2(year); lcdcommnd(0xC5); lcd_decimal2(hour); lcdcommnd(0xC7); lcddata('.'); lcdcommnd(0xC8); lcd_decimal2(min); lcdcommnd(0xCA); lcddata('.'); lcdcommnd(0xCB); lcd_decimal2(sec); MSDelay(100); } }
