RS232 vhd controller
JoseL
Newbie level 5
Newbie level 5
hello everybody,
I’m trying to understand how is working the rs232 controller, and I thing I have understood nearly everything, the only thing I can’t understand properly is how calculate the oversampling value to get the data, I mean the baud rate.
I’m working with the digilent’s code RS232RefComp.vhd (https://github.com/ibm2030/IBM2030/blob/master/RS232RefComp.vhd) , at the line 76 is where the sampling rate is calculated, I copy/paste that line:
constant baudDivide : std_logic_vector(7 downto 0) := "10100011"; --Baud Rate dividor, set now for a rate of 9600. Found by dividing 50MHz by 9600 and 16.
When I do the same operation (50000000/9600)/16 it gives me = 325.5 which is aprox. the double than the one is at the code ("10100011" = 163) if I divide per 32 instead 16 the operations match with of the code.
What I’m doing wrong? What’s I missing?
Thank you very much in advance.
Regards.
baudDivide is used to generate not CLK signal. So Actural TCLK frequency is 2* that name as u calculated.
Anyway i discourage learning from that code. Gated clocks, state machines with wrong sensivity list etc.... there are much easier UART driver codes posted on net
like this one http://www.bealto.com/fpga-uart_io.html
Reactions: JoseL
    JoseL
Take a look at the clock generation it is probably toggling based on the baud rate.
Regards
Reactions: JoseL
    JoseL
Thank you very much for you help and soon reply, I will have a look to the link.
Thanks again.
Regards.
