juaneduardodelgado
Datasheet dude
Im working with a reader of RFID technology.
In datasheet we can read that the output is a FET that it is used as a switch.
The FET switch between V+ and V- what are inputs of the external circuit (external supply). The datasheets describes as follows:
For the GPIO outputs to function, an external user supply must be connected between V+, and V-.
Output high voltage can be V+ if there is a 10k pullup.
Output low voltage can be (V-)+0.5V if there is a 100mA load.
I dont have the internal circuit of the FET switch. That is all the information that I have.
I know what is a 10k pullup. I dont know the internal circuit, but I assume that the resistance garantee the high voltage.
What is a 100mA load? Can anybody help me to understand this?
Im trying to understand this because I design a current amplifier with a TIP31C, and in low voltage in the output of the gpio of the reader, my amplifier turn on its charge (a light).
Thanks
Thanks
