Atif Hussain Shah
Member level 1
What will be the impedance between output and selected input of an RF Switch? What will be the impedance between output and input which is not selected in an RF Switch?
Thanks DanaLots of different kinds of RF switches -
RF switch - Wikipedia
en.wikipedia.org
So what type are you considering ? Power levels you are trying to switch ? Using
it in modulators ? If so modulation rate and signaling.
Sooo many questions.....
Regards, Dana,
I am using ADRF5020.Hi,
we don´t know what switch you use and not the frequency range. So how can we help?
And if we´d know what exact type of switch you use..we need to read it´s datasheet.
I recommend you to read the datasheet.
Klaus
Hi,Hi,
So you have the partnumber. And you want us to read the datasheet and tell you what's written in....hmm
I already asked you to read the datasheet. You need to do this.
It should be very clear regarding your questions.
If there still remain doubts, please refer to the datasheet. Tell us exactly what you understand (in the datasheet) and what you don't understand.
Klaus
You'd got more specific answers by stating the problem from the start, instead of asking general questions.I have a problem in ADRF5020 testing. I have set enable pin to ground and Vdd=4.5V, Vss=-2.45V and Ctrl =5V. I have used 1.5kohm resistor in series of CTRL path. My circuit applies Vdd, Vss and Ctrl signals all at the same time and my switch is not performing switching operation. What could be the reason?
HiNot sure if prevents switching, but according to datasheet, exposed pad must be also connected to ground.
