RF Receiver Interface to AT89c52
Help
Advanced Member level 2
rf reciver
Can we direct interfacing the receiver output to uC? withou connet any decoder IC.
I have one RF transmitter and receiver car remote control. I don't have oscilloscope to measure the incoming receiver. So, i try to write the decode coding and RS232 coding in my uC for simulate. I assumed the receiver generate 16bits output signal, then i will decoded it to 8bits then display the result via RS232.
But the problem is i can't get very actual result and it generate all differents signal.
May i know the receiver output signal will the signal be at a constant bit rate ? and
will the data to be received start will a known start pattern ?
What can i do for my next step?
Thank You.
manchester encoding +code
Ya, you are right. something like yours. but my only got 4 pin which is Out, Ant, Vcc and Gnd.
So what are the following step i need to do?
Thank You.
at89s52 int0 button
At transmitter end connect one micro's TX pin to Data In, and at the receiver end connect receiver Data Out to another microcontroller RX pin, set baud rate to 300 (max 1200) and try to send a byte ..
Regards,
IanP
rc cars using at89c52
1. Make sure the OUT is a TTL level signal, if you don't sure use conection as diagram below
2. Connect the OUT pin to uC and measure the '0' and '1' duration on certain periode (ie 1 second) while the transmitter transmit data
3. The recorded data can be use to recognize the signal
at89c52 remote control car
I don't know where is the transmitter output because i bought the Car Remote Control which is made-ready one. The pcb alot of SMD IC and with 2 big button (i think it builded in with encoded). Latter i will post my transceiver photo. I try to find the output 1st.
"We try to send a byte" means we press the transmitter button then it will send a byte. My microcrontroller will received the data from receiver then how/where can i know the simulate the result through LED display, LCD or PC-Interface but uC only have one RS232. The data will be very fast.
Thank You.
Added after 16 minutes:
budhy said:
Make sure the OUT is a TTL level signal, if you don't sure use conection.
I got but a 7404 between the receiver and uC port.
I try this before. I connect the receiver out to T2EX and set to counter-mode to count the transition every 0.5Sec then show it on LCD. It quite stable.
Is it what you mean?
Thank You.
th0 tl0 10000
No, not like that.
The signal is combination of '0' & '1' stream with difference pulse width, so you have to measure the each pulse. Because we don't know how length the stream is, so measure it at certain of periode (ie 0,5 second)
    Help
interrupt in at89c52
Do you mean we have to measure the '0' time and the '1' time then store each in the Buffer itself. After 0.5Sec we check the time '0' buffer and '1' buffer was taken. Am i rite?
Thank You.
at89c52 rf
Yes!
At a periode of 0,5 second, we'll get many set of signal stream, then we have to select a complete set of steam visually.
    Help
rf receiver dataout
budhy said:
Yes!
I already done the testing that we discuss early.
1) Wrote a Manchester Encoding code.
2) Set Timer0 T0 in mode 1, 16-bit Timer
3) While enter the INT0 Interrupt Service Routine (falling edge) - store TL0 value in Buffer1 then reset TL0 run the TR0 again for raising edge time.
4) While enter the INT1 Interrupt Service Routine (raising edge) - store TL0 value in Buffer2 then reselt TL0, run the TR0 again for falling edge time.
5) If the incoming signal is falling edge 2 times, the Buffer1 store 2 time and the Buffer2 store "0" (entry time). Raising 2 times, Buffer2 store 2times Buffer1 store "0".
I already probe out the graph. There are two type of graphs "transmitter without transmit data" and "transmitter transmit data" but i can't make any conclusion. Please can you check it for me?
Thank You.
Could you tell me your description is for a Manchester Encoding of for RF control signal capturing?
Can you send me the capturing data?
    Help
whi u don't use decoder
i think it will be more easy, i make remote conreol for my car , and i buy a china RF moduls for central locking door (car) , after that i remove the original MCU and connect to 8051 with buffer and after that just reading the buttons :))
regards SYRAX
The code is same as yous but i only add Measure Time and Record for the recording data.
That is another post that you helped me before. This is in assamble language:
State   bit   0
    ORG   0x0000
    AJMP  Start
;*** INT0 Interrupt Service Routine
    ORG   0x0003
    SETB  State         ; it is '1'
    SETB  EXF2          ; transition occured
    RETI
;*** INT1 Interrupt Service Routine
    ORG   0x0013
    CLR   State         ; it is '0'
    RETI
;*** Transition detected (Timer 2 Interrupt Service Routine)
    ORG   0x0023
;   do some thing here
    CLR   EXF2
    RETI
;*** Main Program
Start:
    SETB  EX0
    SETB  EX1
    SETB  ET2
    SETB  EA
Here:
    SJMP  Here
And this is my C language:
void Interrupt_INT0_Routine(void) interrupt INTERRUPT_EXTERNAL_0
//_______________ Measure Time and Record ________________
	TR0=0;
	Buf0[c0++]=TL0;
	if(pulse_state)
		Buf1[c1++]=0;
	else
		pulse_state=1;
    TH0 = 0;
    TL0 = 0;
	TF0 = 0;          // clear overflow flag
	TR0 = 1;          // start timer 0
//_____________________________________________________
	edge = RISING; // 1
	EXF2 = 1;
void Interrupt_INT1_Routine(void) interrupt INTERRUPT_EXTERNAL_1
	TR0=0;
	Buf1[c1++]=TL0;
	if(!pulse_state)
		Buf0[c0++]=0;
	else
		pulse_state=0;
    TH0 = 0;
    TL0 = 0;
	edge = FALLING; // 0
	EXF2 = 1;
void Interrupt_T2EX_Routine(void) interrupt INTERRUPT_Timer_2_Overflow
	EXF2 = 0; // Clear the flag
	if(c0+c1 >= (Bf0+Bf1))
		EX0 = 0; // ***ON External0 interrupt
		EX1 = 0; // ***ON External0 interrupt
Initail Interrupt Routine:
void Interrupt_Routine_Init(void)
    WRITE_TMOD_T0(1); // Set required T0 in mode 1, 16-bit Timer
   ET0 = 0;  // No interupts
   ET1 = 0;  // No interupts
   IT0 = 1; // set(1) 1-to-0 transition
   IE0 = 0; // set the init transition to "0", waiting 1-to-0. Clear the flag
   EX0 = 1; // ***ON External0 interrupt
   IT1 = 1; // set(1) 1-to-0 transition
   IE1 = 0; // set the init transition to "0", waiting 1-to-0. Clear the flag
   EX1 = 1; // ***ON External1 interrupt
   ET2 = 1; // ***ON External2 interrupt
   EA = 1; // ***ON
Do i right?
Thank You.
Added after 1 minutes:
What you mean? Can you show me your circuity connection and explain how you wrote your code?
Thank You.
Try this:
char time[20];
void capture_idle_1(void){
char i;
     while (IT0) ;
     i = 0;
     while (i<20){
            TH0=0; TL0=0; TR0 = 1;
            while (!IT0); TR0 = 0;
            time[i++] = TL0;
            while (IT0);  TR0 = 0;
            time[i++] = TL0;
void capture_idle_0(void){
char i;
     while (!IT0) ;
     i = 0;
     while (i<20){
            time[i++] = TL0;
            time[i++] = TL0;
void main(void){
     TMOD = 0x01;
     capture_idle_0(); // if the idle state on IT0 is '0'
     capture_idle_1(); // if the idle state on IT0 is '1'
Connect OUT signal to IT0
    Help
Thank for your sample code. I learn new thing with you. We can't use IT0 for knowing the incoming signal, i think is because for setting perpose (set "0" invert incoming signal, set "1" 1-to-0 transition). So, i change it to IE0. Then connect the OUT signal to INT0.
But i still can conclude again from the graphs. :cry: Is it the we use TL0 to measure is too accurate. So we can't conclude it.
#define time0 71
#define time1 71
idata char time_idle_0[time0], time_idle_1[time1], i;
     while (IE0) ;
     i = 0;
     while (i<(time1-1)){
            while (!IE0); TR0 = 0;
            time_idle_1[++i] = TL0;
            while (IE0);  TR0 = 0;
     while (!IE0) ;
     i = 0;
     while (i<(time0-1)){
            time_idle_0[++i] = TL0;
     return;
void main(void){
     TMOD = 0x01;
	 IT0 = 0;
	 while(1)
	 	capture_idle_0();
	 	capture_idle_1();
One more thing, i discover one thing. I have Frequency meter. I measure the Receiver OUT the signal unstable(in Hz). And i try to find the Transmitter OUT but i'm not sure whether that's the output not.. because i have to press the Switch then got frequency is ~550Hz and it make the Receiver stable in ~550Hz also.
I wanna to say Thank you again.
Thank You.
This time I don't use inverter, just direct connect OUT signal to INT0, and use polling technique to measure signal 'space'/'mark' duration!
Beside that you have to measure the idle (no RF signal) voltage at IT0, then decide use time_idle_0 or time_idle_1, I mean you don't need the 2 function together, but choice 1 according the idle volate at IT0.
When I'm playing IR remote control signal, normally the 'space'/'mark' duration is smaller than 200 micro second, so I only use TL0.
Sorry I make a mistake, not IT0 but INT0
#define size 70
idata char time[size];
char i;
     while (INT0) ;
     i = 0;
     while (i<=size){
            while (!INT0); TR0 = 0;
            time[i++] = TL0;
            while (INT0); TR0 = 0;
            time[i++] = TL0;
char i;
     while (!INT0) ;
     i = 0;
     while (i<=size){
            time[i++] = TL0;
            while (!INT0);TR0 = 0;
            time[i++] = TL0;
void main(void){
     TMOD = 0x01;
     IT0  = 0;
     // choice one only, capture_idle_0() or capture_idle_1()
     capture_idle_0(); // if the idle state on INT0 is '0'
     capture_idle_1(); // if the idle state on INT0 is '1'
What is the part number of the RF Receiver chip?
    Help
Is it we set IT0=0 then the uC will know we are using Inverter? If we no use IT0 function then can we use other port pin?
Yes, your measure signal 'space' & 'mark' duration is work. Good.
Finally the graph comeout with standard pattern already ha.. But what we can know from the graph?
I wonder why i have to capture_idle_1 then get the result when Switch is press, please can you explain to me? what you mean measure the idle voltage IT0, how to measure IT0, is it measure the INT0 pin without connecting Receiver Signal? If initial is Hi then we select capture_idle_1?
If our code select capture_idle_0, the result all the time is the same.
I don't know the RF Reciver part number but it states KXDJS2024 15.04.2005 there. Is it tht's what you wan? The RF Reciver is from the Central Locking Car, i thought from China.
So, what's the next step we have to do?
Thank You.
No, doesn't like that
Set IT0=0 mean we'll monitoring INT0 pin as logic level ('0' or '1')
Set IT0=1 mean we'll monitoring INT0 pin as logic transsition ('1' to '0')
In our case, IT0 doesn't take any effect
IT0 just define how to trigger IE0 flip flop, no other function
I hope this illustration can give you a clear situation
Use voltmeter to measure the voltage at INT0 pin when no key pressed, the '0' or '1' of INT0 at that condition determine whether you need time_idle-0 or time_idle_1.
We don't need graph, but the number (periode of 'Space'/'mark'). Each key has it own unique 'Space'/'mark' number, it is the what we recoqnize which is the key pressed.
Please re-capturing the 'Space'/'mark' number of each key, and send itu to me.
(do it once for each key)
    Help
Thank for your good explanation. It very helpfull for me.
What your mean re-capture the 'Space'/'mark' number of each key?
I already done it. Is it any problem in Graph2?
- Test1 and Test2 in Blue color graph is for Switch 1.
- Test3 and Test4 in Green color graph is for Switch 2.
- Test5 and Test6 in Yellow color graph is for Switch 3.
I capture 2 times for each key/Switch for us to do comparison.
If wan to re-capature the 3 key again, please let me know again. I will like to do it again.
Thank You.
Some question:
1. You use idle_1, it mean when no key pressed the voltage at INT0 is '1'. But why there is idel_1 no data graph? Does it mean without any key pressed there are still a pulses stream on OUT pin?
At this case I think you have to use osciloscope to make sure
2. What is the meaning of CYCLE (blue bar)?
Beside the graph, would you like to send the raw data too?
    Help
