haroon_tech
Member level 2
hi,
i done programmer ckt(made it on GP board) ..in that ckt one end of resistance and zener diode's negative terminal are shorted and given to controller and positive terminal of zener is grounded, other end of resistance going to db9's pin4 ....
while testing the resistance with multimeter....i got resistance is shorted(it is beaping(sound)) ,
then if change polarity of multimeter probes again i tested , this time resistance is not shorted(means it is not beaping)..............is this normal ..............or resistance is gone(short ckt).......
this testing is done after giving power supply..........
