Jul 20, 2005 #1 R rahul_sanghavi Member level 2 Joined Dec 7, 2004 Messages 47 Helped 0 Reputation 0 Reaction score 1 Trophy points 1,286 Activity points 404 dspic30f6014 schematic Hi all, I am looking for a PCB footprint of the dsPIC30F6014. The datasheet defines it as 80 Pin TQFP. I use Protel 98 for my schematic and pcb development. Regards Rahul
Jul 20, 2005 #2 T Taew Member level 1 Joined Apr 13, 2005 Messages 35 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,551 layout dspic30f6014 you can easily create the footprint yourself. Here is the link from IPC you can check **broken link removed** (this is for footprint calculator) and this is the website for IPC land pattern standard h**p://www.trax.co.za/IPC/IPC-SM-782A(L).PDF Added after 14 minutes: sorry here is the file
Jul 20, 2005 #3 H House_Cat Advanced Member level 4 Joined Feb 21, 2002 Messages 1,369 Helped 406 Reputation 812 Reaction score 98 Trophy points 1,328 Location USA Activity points 16,416 If you don't want to, or can't, make your own footprint, attached is a Pr0tel 98 library with a footprint that will fit your device. The one you want in the library is named QFP14X14-80(N).
