Aug 26, 2008 #1 A avr_micro Member level 3 Joined Feb 15, 2004 Messages 64 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 514 Hi everybody, I want an analog circuit which can be replaced relay. A and B can be any signal and c is the on/off command signal.So this circuit should be conduct any signal with maximum 1A current. regards,[/img]
Aug 27, 2008 #2 E Eugen_E Full Member level 6 Joined Nov 29, 2004 Messages 383 Helped 44 Reputation 86 Reaction score 11 Trophy points 1,298 Location Romania Activity points 2,862 You should tell where u want to use it. For small signal applications, look for 4066, 4053, 4052, and other CMOS switches. It can be discrete too, with diodes, or MOS.
Aug 27, 2008 #3 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,478 Helped 14,756 Reputation 29,794 Reaction score 14,120 Trophy points 1,393 Location Bochum, Germany Activity points 298,338 Solid state relay is the general term for it, there are plenty of devices avilable with different current and voltage ratings. DC capable relays are generally using anti-serial MOSFETs and e.g. a photovoltaic gate driver, if isolation is required.
Sep 3, 2008 #4 A avr_micro Member level 3 Joined Feb 15, 2004 Messages 64 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 514 but i need something which can be in scale of smd.
