Dear All,
I am a student with primitive experience in verilog. I have a small verification task for a top module. I have simplified the task in the below description, so that you can give me a quick response. There could be solve for this problem in various ways. But ideally I am finding a solution to create an automatic test setup.
Please find below the problem. If you could write me a solution with a working example in verilog, that would be a good starting point.
Write a Script or Test bench for the following tasks;
Send Data = 8 bits and Received Data is 16 bits.
1. First Send Data for 0-256 data frames with STATUS_IN = 0, and then again Send Data 0-256 data frames with STATUS_IN = 1
2. Next send few control frames of 8 bits with specific pattern (e.g. 8'b00110101) again with STATUS_IN = 0 and STATUS_IN = 1
3. Compare if Send Data == Received Data at the DATA_OUT port. Also compare if STATUS_IN == STATUS_OUT for every received data frame
4. Print SUCCESS or FAIL for every data frame transmission in a File (use File handling)
File handling: Print Send Data and Received Data, Print STATUS_IN and STATUS_OUT and SUCCESS and FAIL for each data frame transmission
One additional task is to breaking 16 bits Received Data in two 8 bits for each cycle. Find attached the diagram of the module.
Thanks and Regards,
