REQ: S-PARAMETER FOR 2n2222 & 2n3904
bobcat1
2n2222 and s-parameters
Need S-PARAMETER FOR 2n2222 & 2n3904 bjt
thanks
bobi
s parameter model for 2n3904
These are not small signal RF transistor. You can calculate the S parameters with spice. But you have to take the package into consideration. Infineon and Philips semiconductor web sites are good places to find spice models.
2n2222 and 2n3904
It's VERY uncommon to ask for S-parameters for these low frequency transistors. Are you sure you have not got it all wrong?
In any case. at what bias (IC and VCE) do you want the S-parameters? In which configuration? Common emitter? What frequency range?
s parameter 2n3904
I need it for design a match to simple CE amp for 4 Mhz
Vcc 5V
Ic = 10 mA
q2n2222 pspice parameters
At this frequency you can use the hybrid pi parameters to make a simple lumped element equivalent circuit. You then use ordinary hand calulations to make the source and load networks.
s-parameters 2n3904
Hi
This app. note from cadence is very interesting about this subject.
h**p://w*w.orcadpcb.com/pspice/applicationnotes/tn10.asp?bc=F
