Remove netlist from Allegro Board ..Help me, urgent!!
sugvivek
Member level 2
Member level 2
Dear All,
How to remove the entire netlist from allegro board.
Help me.!!
neena
Member level 4
Member level 4
pluto
hi
You con't delete the netlist from the Allegro Board
You can change or delete from the schematics only
binu G
Advanced Member level 2
Bangalore
hi,
It depend on your licence, if you have SI610 or higher then you can edit the net in the layout.
so neena correct urself.
Binu G
centiago
Full Member level 3
Full Member level 3
Lions Den
Well deteting component or nets are not possible.If you delete component, it resided in place option & doesn't og off the design.
The only way is to edit schematic & reload netlist after packaging.
Good luck.
binu G
Bangalore
Good luck.
hello Centiago,
i wonder that will the netlist too reside in place option !.
change the licence suite to si630
you can see Logic --> partlist
logic -- > edit nets
u can do wht ever u want it wont be in ur place option. try this!
binu G
centiago
Full Member level 3
Full Member level 3
Lions Den
Binu,
Best practice calls for change from schematic, when you edit schmatic & repackage, old netlist are replaced with latest design.
Read carefully, the question in thread was to remove the nets from design. There's absolutely no way you can delete nets on .brd file
binu G
Bangalore
Crentiago
u seem crazy !
not willing to agree.
i do understand that you have to delete from the schematic. but you can also do it in board file.
read the question carefully.
"How to remove the entire netlist from allegro board. "
not from schematic.
send me a file i will show you how to remove it :p
binu g
majnoon
Full Member level 5
Full Member level 5
You DO NOT need to change editor.
Go to setup>User Preferences select Misc category then check logic_edit_enabled
This will allow you to remove nets and components from logic>net logic or logic>part logic menu.
Now if this is a proper way or not is entirely different issue!
Majnoon
