relay selection for 3 phase motor
Manjust
Hi all,
All i want to know is what type of relay i am suppose to use to switch a 3-phase motor or an AC input device?
What i thaught is to use a solid state relay. Am i right??
hello,
In industries, it's common to use Solid state relay to drive heaters
but power relay to drive AC motor, mainly for safety reason
even after power relay you use a Power unit to control the speed..
and a thermal-magnetic tri phases breaker (disjoncteur) , calibrated on 1,2 x times nominal Intensity
to protect the motor.
hello,
Thank you paulfjujo. What exactly does thermal-magnetic tri phases breaker do? and even i taught of using SSR. i will study what exactly is that get back to you.
Thank you
hello,
Gives some details : what is the power of your AC motor ?
here is an example of breakers to protect the motor
... combine with fuses !
must exist on many brand marks..
  • GV2ME08-Telemecanique.pdf
