sakibnaz
Full Member level 3
Hi all.
I have a ques ... regarding the best professional way to control Power (ON/OFF) of some Sensor (Light, Microphone and IMU) which I like to drive by 3.3V.
My system is Li-Po 3.7V Power and it have Boost 5V for CPU and 3.3 LDO for MCU supply.
Now I like to have this three Sensor but I want to have full Power ON/OFF Control where when in Sensor OFF Mode I want the related Power Control Circuit for the Sensors will consume as minimum possible Power (almost zero amp).
FYI please see the attached for my system Block diagram.
Now what will be the best way to apply Power to the Sensor? I planned use extra three small LDO's (Input 5V and Out 3.3V) and supply to each Sensor where LDO's 3xEnable Pin I can connect with 3xGPIO to control. But not sure if its good idea.
Please advise.
Thanks.
Please advise.
Thanks.
