spef crosstalk inputs cdb command file
Following is the celtic cmd... plz clarify me few things...
celtic cmd :
read_dotlib -typ $libpath/typical.lib
read_dotlib -max $libpath/slow.lib
read_dotlib -min $libpath/fast.lib
load_netlist \
-top aesctr_top -verilog top.v \
-cdb $cdbpath/typical.cdB \
-spef_annotate filespef.spef \
-vdd vdd -gnd vss
check_timing
process_netlist
read_dc_script constraints/constraints1.tcl
calculate_delay
#set_analysis_mode -single -setup
report_timing -format {instance cell arc load slew delay arrival required}
report_analysis_coverage
report_clocks
#Analyze SI Effects on timing
analyze_noise -delay
generate_report -sort_by noise
After this generate command,
Report Options:
Slack : yes
Sort by : noise (receiver input peak)
Threshold : 10.0 (mV)
Level : VH and VL
Peak(mV) Level TotalArea %AreaTillPeak Width(ps) VictimNet
612.421 VH 216.37 26.85 706.61 ../mc_cntr_out_reg_101_
{../mr_out_temp_101_}
Receiver output peak:
Value ReceiverNet
26.718 (270.000) c_cntr_out_reg_101_/D (SDFFRX1)
Constituents:
Source Peak(mV) Offset(ps) Slew(ps) Xcap(fF) Edge Net TraceBackNet(NoiseType)
Cpl: 216.575 4880.000 121.338 29.147 F ~../mc_cntr_out_temp_101_ -
Cpl: 101.807 4820.000 167.236 15.123 F
aes_pr_key_in[425] -
Cpl: 83.712 4860.000 138.489 11.486 F u
Here what is this report infer?
How to analyze here....
what r the things we have to consider here???
How to generate sdf?
what we will see in glitch analysis and noise analysis report?
How i come to know this is violation or not?
Then timing summary i found in setup :
No of check: 100
setup : 90
untested: 10
means, what it means untested..
how to see the untested path in PT... it means false path ?
Thanks in advance
DIN
Added after 16 minutes:
celtic cmd :
load_netlist \
-vdd vdd -gnd vss
check_timing
process_netlist
calculate_delay
report_clocks
Report Options:
Slack : yes
Level : VH and VL
Value ReceiverNet
Constituents:
No of check: 100
setup : 90
untested: 10
Thanks in advance
DIN
