Well that sounds good but a bit complicated for my aptitude level. Is there an easier way than this? For instance, I set sonnet 3d em simulator as my em simulator in AWR for a particular em extract doc of my desired choice. Then I clicked "view em structure in native simulator" in AWR. Now the EM layout was opened up in sonnet window. But when I tried clicking "view currents" in sonnet, it said "cannot view currents, make sure you have analysed your design with the sonnet current density viewer". Also I am not able to duplicate the *.son file (EM extract doc that AWR generates that is viewed via sonnet) as sonnet gives me the error message saying "*.son EM extract docs created via AWR cannot be saved as inside sonnet"....Hence I see a deadend as far as a straightforward approach for this is concerned.
---------- Post added at 02:55 ---------- Previous post was at 01:31 ----------
@Volker, I extracted a .net netlist file from the awr schematic and tried opening the .net netlist file from sonnet. But sonnet crashes and says unable to open it. But I have a gut feeling there must some easier way to do this. Can anyone help on this?
