Reducing the power consumption by reducing the crystal frequency
microlab
Full Member level 5
dear friends
as all of you know that AT 89c51 will work up to 24 Mhz
i was using 12 Mhz crystal
i came to know that we can reduce the p[ower consumption by reducing the
crystal frequency.what will be the difference if i use a 2 Mhz cryatal?
how much power we can save ?
thankung you
ml
8051 power saving
... and watch out - depending on your application, is might be NOT the microcontroller which has the bigger power consumption...
Also, be aware that there are other techniques to reduce power consumption, for example decreasing supply voltage e.g. using 3V parts; putting the part into some of low power modes (classical '51 has 2: idle and powerdown) from time to time...
wek
Re: 8051 power saving
Watch out for selected latches, buffers and memories in your system, a selected memory can draw tens of miliamps, even if the outputs aren't active. Also, if you have a serial EEPROM, you might consider increasing the clock frequency to quickly complete the transactions, rather then bothering to obtain a few tens of microamps by lowering it
lower frequency and lower power
