real number implementation in vhdl
ravi33811
hi i have to perform real num addition.
i will use the single precision format.
can i give the input as a real num
for ex:4.5.. is this possible in vhdl
can any one help me how to convert real num into binary.. using vhdl
i am not getting how to proceed
Iouri
Advanced Member level 2
if it is only one digit after comma, I will use BCD convention, in this case 4 LSB will represent your .5 and do all the math based BCD format
in case of 16 bit your max value will be 999.9
echo47
Advanced Member level 5
USA
VHDL supports the real data type directly. No need for conversion.
However, many synthesis tools don't support real, but that's a different issue. Some tools provide various workarounds (such as core libraries) for doing floating point calculations. Or you can scale all your arithmetic algorithms so they fit conveniently into integers or fixed-point.
ravi33811
hi thanks for ur reply .
but how can u actually test it on the hardware.....
vinodkumar
Full Member level 5
hyderabad
hi,u can look for either ip cores or look for libraries which allow u to write code for ur operations by including them,two such are available under ieee_proposed libraries.
fixed point and floating point packages.
u will find these in this board.
i hope this helped u.
ravi33811
hi can any one tell me the logic to convert real to binary.
how would u seperate the integer from the decimal value
