random generator verilog source code
openwindows
Junior Member level 3
verilog random number generator
who can post?
gauiver
Member level 5
Member level 5
random number generator verilog
there is a confusion here. are u asking about the internal structure of saics thnat what internal structure comes out or something more related to some software like max+2. plz clear this but in any case u will find this useful
1 warning (-5 posts, - 20 points) , attachment deleted
1 - This post has nothing in common with the request made
2- This file was uploaded 1000 times on elektroda. And most of all
it is freely availlable on the web !
gauiver
Member level 5
Member level 5
verilog random
vow thats more than a whole course in a semester. well u can find alot on this site there are a lot of e-books on asic on asychronous designing and also do check this attachment it will also be helpful. i think that u should rfeally check this site becaz i think i have seen quite a big amount of data on asychronous design, about 20mb. and by the way what are u doing becaz i haven't studied all of them in my course.
it_boy
Full Member level 3
Full Member level 3
random verilog
Hi Benny,
If it is just a random number generator you want, attached is a pseudo random number with 15-bit polynomial generating a 64 bit parallel output
philewar
Member level 4
Member level 4
Shanghai
verilog random function
Hello,
How about true random number generator?
I think it must read some real random seed external, right?
Thx.
it_boy
Full Member level 3
Full Member level 3
$random in verilog
I think nothing like a true random number. the randomness depends on the length of the seed value and the polynomial used.
Whatever be the seed value used, the random pattern a random pattern generator can generate will be same, depending on the polynomial. Seed value only defines the starting value of the random number.
Somebody please correct me if I am wrong
philewar
Member level 4
Member level 4
Shanghai
random number generator in verilog
Hello it_boy,
hmm, maybe you are right.
What about if the source is from a white noise or sth. like?
maxplus1000
Junior Member level 1
verilog $random
Could this random generator be synthesisable?
philewar
Member level 4
Member level 4
Shanghai
verilog random generator
LFSR is synthesisable while other pseudo random number generators are only for simulation.
maniasonic
Member level 1
Member level 1
verilog random number generation
a true random generator is definitively impossible to come out as a synthesible digital design...sigh...
samlee
Newbie level 3
Newbie level 3
random number generator verilog code
How random it is? I mean how many number will the value be repeat again?
always@smart
Full Member level 4
Full Member level 4
ASIA
prbs verilog
Dear all,
Anyone has the code or info for the Random number generator and the Random number verifier. I've to design for the transceiver, which transmiter has 8-bit PRBS and the receiver has PRBS verification.
Any infomation is highly appreciated.
Thank you in advance.
Regards,
Alwys@smart
baonguyenpro
Member level 2
Member level 2
pseudo random number generator verilog
Linear Feedback Shift Register
Pseudo Random Binary Sequence
You can find in book: "Rapid Prototyping of Digital System"
"HDL Chip Design"
Application Note of Altera, Xilinx.
sparso
Member level 3
Member level 3
prbs generator verilog
I need to design a prbs generator and analyzer for a loop-back test. Any idea where I can get some info?
jasonkee111
I have use a simple LFSR to generare random number. Set of random number are pass through to FFT(power in db vs freq). However, the freq response is increasing at low freq. Then only maintain roughly flat for higher freq. Is there any problem with increasing at low freq?
If yes may i know the reason?
FYI, lot of white noise freq response is almost flat from low to high freq.
Thanks
