Raju C
Hi all.. I am doing a program for analog radio so i need to take care of the below steps..
1.Rotating BCD SWITCH (KNOB)0000 to 1111
2.GOTO PERTICULAR CHANNEL
3.STORE THE INITIAL DATA
4.Interrupt PTT
5.If 1 go to TX data to calculate else RX data to calculate
6.RETFIE
7.go for channel changing again
I am getting confuse in channel changing loop.. when i change channel it should locate to peticular specified data .. inbetweeb interrupt occurs so it works fine .. but in that code if i enter channel it is not taking perticular value . so how to do that i am not getting pls help ..
4.Interrupt PTT
6.RETFIE
