Question regarding Audio codec chips
howie
Member level 2
Philippines
codec chips
An AUDIO CODEC chip (WM9731L by Wolfson) have pin outs:
1. SPKR
2. SPKL
3. OUT 3
4. OUT 4
5. GND
What is the difference between the SPKL/R pin and OUT 3/4 pin? Does it mean that I need a speaker with 3 terminals (for SPKL/R, OUT3/4 and GND)? Can someone help me regarding this coz Ive only encountered speakers with on;y 2 terminals.
Thanks!
hubble247
Newbie level 1
UK, Southwest
Wolfson often label additional outputs as OUT3 and OUT4. These can be used as outputs or can be set to mid-rail and used as phantom grounds if you want to go capless. If you use caps then you don't need to use OUT3 and OUT4.
BUT read the datasheet it should explain.
cameo_2007
Advanced Member level 3
12°58' N77°38'E
you may connect it as shown:-
Added after 2 minutes:
Oops!! i didnt notice that it was asked ages ago.
bert_kak
Member level 5
Philippines
Re: codec chips
1. SPKR
2. SPKL
3. OUT 3
4. OUT 4
5. GND
Thanks!
Those 4 outputs can be configured depending on what audio output do you want.
see page 53 Auxillary output (pins 37 and 33)
- source for these outputs can be from INV1/2 or Vmid, you just need to set the desired register for these mixer outputs
see page 52 Speaker output (pins 35 and 36)
- source for these output can be from HPMIXL/R, SPKMIXL/R, INV1/2, Vmid, you just need to set the desired register for these mixer outputs.
    howie
