Question about Watt meter reading
neoaspilet11
Full Member level 5
Cebu, Philippines
wattmeter reading
Hello Guys,
From the Definition of AC power
P = VIcos (theta)
where theta is the phase angle between the voltage and Current,
If this phase angle is 90degrees or 270 degrees, will the meter reading be zero?
because cos(90) = 0
Thanks,
jack
Re: Watt meter Reading
Yes the power that is measured by the wattmeter of our houses does not measure the reactive component of the power consumed so if the load is purely reactive (capacitive or inductive) it will not be measured. In industrial applications however there is a penalty for reactive currents and we use power factor correction devices.
Watt meter Reading
yes the watt-hour reading is zero becuase for reactive loads there is no power dissipated ,as the power absorbed for one half cycle reloaded for the other half cycle.
