tang76
Junior Member level 1
Dear all,
I need to simulate the induced voltage in received coils by transmitted coil. I have successfully do it by eddy current model, the method is to set 1 A current on the transmit coil and then calculate the impedance matrix of coils, as a result, the elements of matrix is just the induced voltage. The result is agree with the analytical result.
However, when I try to solve the same problem by transient method. I got the wrong result. The induced voltage is calculated directly, but it is the time domain. By the FFT, I can convert it to frequency domain. Now the problem is the result in frequency domain isn't agree with the analytical result.
I think the FFT is correct, that is to say, there is some problem in the model by transient method. Could anyone help me to check the problem of transient model?
I have attached both project, wish someone can solve my problem and let the transient method also get correct result.
Thanks
Thanks
