Hi all
I am working on LVDS tx in 130nm technology for transmitting 250Mhz clock (Schematic enclosed)
I have a Query regarding Gain of CMFB amplifiers
According to Common mode & differential mode output swing Specification I decided
The transistor sizes of output switching network
Now MN2 size comes out to be very high & MN2 Cgs = 992.2920f & cgd = 91.2043f
For MN2 gate drain capacitance nearly equal to
Cgd + Cm = Cm = suppose I take 3pf
Total capacitance seen on gate source of MN2 is
Cm / (1-Av) + Cgs which is nearly equal to Cgs
Hence bias current should be decided by Cgs & slew rate of CMFB ckt
I = Cgs * dV/dt
How much slew rate I can take 4 this CMFB ckt ?
Only thing I m observing here that if I used lower bias current CMFB ckt hence it is very less 2 drive out huge MN2 current sink
CMFB transistors sizes are also large ???
Please help me.
Thanks & regards
Sunil
